If my car does not sell i've decided to tune her up to keep me interested. What would this take and who would u guys trust to do the work? and any idea on what the cost would be around?
Decat
Up-rated intercooler or charge cooler
forged pistons (some would argue forged conrods too)
uprated fuel pump
870cc injectors
bigger turbo (GT28 and up)
Stand alone ECU
400bhp is easily achieved, but for the same cost you could opt for bigger injectors and turbo and get 450bhp +
Gonna cost at least £5k I reckon.
Yes if you go for the right turbo
The limit of the stock engine and fueling system is about 270 - 280bhp at the wheels and that's only with seriously good charge cooling and a stand alone ECU.
To go above that level there are no short cuts I'm afraid. A forged engine re-build, ECU and bigger turbo are absolutely essential.
mattcambs wrote:Decat
uprated fuel pump
870cc injectors
Stand alone ECU
A gt28xx turbo aint gonna get anywhere near that power,
For 400+ you wanna be GT30 family +
TOTB 2010 Rwd top speed, 1/4 and shootout winner.
10.7@142 on R888 street tyres, 10.3@134mph on slicks,
9's on slicks to come, with a clean full throttle pass! Goal of 0-150mph in a 1/4 of a mile....
Get a quote from Rogue. It'll probably be the most expensive, but you will get the correct spec for your power goal and the right attention to detail concerning the re-build.
What credit crunch, eh?
mattcambs wrote:Fo Sure I didn't realise he meant wheel power.
Neither 400 flywheel..... .....unless in america
With the bigger variants of thre GT28 you should be able to get close to 400fwbhp on a fully built motor/charge cooled/good map
I agree, though, it would be far better to run a GT3071
hi there i have a gt2876r and a fully built block and port and polished head ecu,chargecooler ,cams you name it ive got it and rogue did all the work and lyndon did all the mapping and it made 358 at the wheels so thats over 430 at the flywheel but that is the max on that turbo been told to go for a gt3076r if i want more power
turbo wrote:hi there i have a gt2876r and a fully built block and port and polished head ecu,chargecooler ,cams you name it ive got it and rogue did all the work and lyndon did all the mapping and it made 358 at the wheels so thats over 430 at the flywheel but that is the max on that turbo been told to go for a gt3076r if i want more power
Thats great power from that turbo
What boost you having to run through it?
I bet its a rite hoot to drive
hi there as i said lyndon from rogue motorsport set it up and its running 1.97 bar on top setting.ive got 4 setting and running 1 bar on the lowest one and yea its great fun to drive.the guys from rogue are well happy with them figures as well from that turbo
