Can anyone recognize this head ? is it from a rev 3, it looks different to my rev 2 ? apparently its been
"gas flowed and re skimmed all to Toyota specs and valves " ?
[Mk2] [Turbo] Whats this head off please?
Re: [Mk2] [Turbo] Whats this head off please?
u cant tell alot from that photo, you got a rev3 head and thats about it. take some more photos of the combustion chambers and the ports and it should be obvious if something has been done.
cheers karam
cheers karam
Well you answered the question its a rev 3
What will be obvious its had work done ? apart from being clean?
usualy there are some rough casting marks inside the ports, if its been flowed then it should be smooth and almost chrome like
cheers karam
cheers karam
Thanks ill have a look
Cant tell much, heres another couple of pics ,looks like some damage where a head bolt has been removed ,does this make it scrap value only?
that hasnt been ported, looks standard to me
Ah well, you cant believe everything you read
thanks
thanks
