It still needs a lot of work but so far ive replaced
volts
oil pressure
water temp
tacho
and an extra gauge which is oil temp
![Image](http://img.photobucket.com/albums/v624/paddy1970/woodsport2/27092008092.jpg)
The only ones i haven't managed to replace are fuel gauge and speedo.
A quick vid showing it from different angles.
http://uk.youtube.com/watch?v=Q3B25W3Yeds
I like this dash because it shows the values as actual numbers instead of needles that aren't giving you the full picture,for example i now know exactly what volts my alternator outputs at any given time instead of guessing.
Im planning on making chrome or aluminium bezels for each display to finish them off.
