Windows washers, horn, stereo don't work! Is it a fuse?
fermanagh
Post by fermanagh »
Please help - i'd like to fix this myself
JohnnyC
Re: Windows washers, horn, stereo don't work! Is it a fuse?
Post by JohnnyC »
It could be, why don't you check the fuse?
fermanagh
Post by fermanagh »
Have'nt got a clue about mechanics unfortunately...where do i look?
JohnnyC
Post by JohnnyC »
Should be in the front fusebox (under the front bonnet - next to the passenger side popup headlight) - the underside of the lid shows you what fuses are for what - take out the appropriate fuse and see if it's blown or not.
If none of the fues in the front bonnet are for the horn/washers etc, then try in the fuse box in the drivers footwell - under the front bonnet release catch.
Return to “Electrical”
