I have searched but cannot find anything about removing this fuse.
Can anyone help me and let me know how to remove the white 120 amp alternator fuse from the front fuse box, mine has fefinitely blown but I cant work out how to get it out without breaking something.
Cam
[Mk2] [NA] 120 amp fuse removal
Re: [Mk2] [NA] 120 amp fuse removal
From what i was told you have to undo a bolt at the bottom of the fuse box to get it out.
just took a pic for you
fuse rack = the plastic thats got the big fuses on
First you have to unscrew the fuse box off the body. Then to unclip the fuse rack at the top and pull the fuse rack out of the fuse box. Then you get to unbolt the 120amp fuse
hope that helps
hope that helps
Henry Ford "Any customer can have a car painted any colour that he wants so long as it is black"
Modifying a 1 liter is like giving my granny a E. It’s just wrong!!
Thanks for that, got it out now should be back on the road tomorow..............
Cam, you get it sorted yet?
No problems, got one from MrT and fitted it in 5 minutes on Saturday.
Took longer for the alternator to come, fitted that yesterday and everything is back to normal.
Will teach me to disconnect the battery next time I work on the alternator.
help with blowing 120amp ALT fuse mr2 mk2 rev2 uk spec
Hi ive been searching the internet for anything on the ALT 120amp fuse as my keep blowing as soon as its put in, what was your issue was it the same and a new Alternator was fitted, can i test the alternator to see if this is causing the issue, i have removed all the other fuses except far left one and it still blows, any help would be great
