[Mk2] [Turbo] Radiator fans
Mine are constantly on... I removed my air con radiator off front by just disconnecting it is this why my radiator fans are now constantly running?
Re: [Mk2] [Turbo] Radiator fans
Yes mate you are correct.
The fans are controlled in part by the air con ECU and should the ECU see anything not quite right (in your case a missing rad sensor) then it'll engage safety mode which puts both fans on full blast all the time.
Where is this located this switch or how do i get round it?
