Hi,
I have a problem that is similar but not exactly the same, looking for advice that might help both of us
My car is a 1991 Mk2
(SW20) import with a 3SGE engine.
My car overheats quite randomly, and the problem looks on the face of it like a sticky thermostat, i.e when it does overheat or look like it is going to 99% of the time the guage will suddenly drop back to normal temperature.
The only things that are confusing me are that the last time it overheated properly
(didn't drop away like normal) the temp guage was through the roof, yet the heater was blowing ice cold air.
As I understand it the heater on this engine
(3SGE) should circulate water independently of the thermostat.
or should it?? On this occasion I stopped the car, let it cool, refilled the water and carried on.
This time it behaved and we suddenly got warm air.
The other thing is the manner in which it overheats.
If I drive the car like Miss Daisy it behaves fine, but if I give it a little stick, especially if I take it over the power valve at 5k rpm it will almost guaranteed overheat the next time I slow down.
If it was just a sticky thermostat then surely it would stick regardless of how the car was driven?
When it first overheated I checked the head gasket by looking for leaks, looking for mayonnaise in the oil and compression tested the cylinders.
That is all fine.
The rad cap also holds pressure until it overheats completely then the valve blows off with a nice niose like a boiling kettle
(takes a little of the sports car
"cool" away)
Any ideas would be much appreciated.
Tar.
