Idle speed
acexxx
Idle speed
Post by acexxx »
Hi there. When I got my car it wasn't idleing. It was at 700 rpm and kept cutting out. I have adjusted it now but I think its to high 1200rpm when hot. Whats the cold idle speed and the hot idle speed meant to be?
Mk1 Turbo Powered Steve
Re: Idle speed
Post by Mk1 Turbo Powered Steve »
From my limited knowledge, it should be around 1500 cold and settle down to about 900 when hot but it's been a long while since i had an NA.
un1eash
Re: Idle speed
Post by un1eash »
Cold can be anywhere upto 2.5k and hot is around 800rpm
Tony jinxy froude
Re: Idle speed
Post by Tony jinxy froude »
Your best bet is to run the car to normal temp I.E eactly half way up the temp gauge, then adjust the idle, i find that 950rpm is a good place for the idle to be, Jinxy
WeirdNeville
Re: Idle speed
Post by WeirdNeville »
Do you need a tming lamp to do this, or can it be done by tweaking the Idle Control Valve whislt using the tacho for reference?
jimi
Re: Idle speed
Post by jimi »
The NA doesn't have a ICV. It's just air screw adjustment :wink:
Tony jinxy froude
Re: Idle speed
Yep just use the tacho, its easy, especially if you stand on the passenger side of the car with the engine lid up & peer through the vents at the gauges in the car you should be able to see the tacho through there, easyier than walking around the car every few seconds :thumleft: Jinxy
