my tyres fitted on the front are 215,45,17's and during turning rub on the black plastic on the wheel arch, the car is lowered with springs and on yellow billies,
what size is needed to clear the plastic trim?
on the rears are 245,40,17's what effect on handerling would be if the fronts where 215,35,17 or 215,40,17s? would I notice anything?
[Mk2] [Turbo] front tyres rubbing on the rear wheel arch during turning
Re: [Mk2] [Turbo] front tyres rubbing on the rear wheel arch during turning
225/40/17 will clear
235/40/17 will clear depend on offset/ spacer (also coilover apexi clear, tein need spacer)
235/45/17 cannot turn the wheel at all   but will fit
Your front tyres are rubbing on the rear wheel are when you turn?
My fronts were 215/40/18
Just don't turn as much, job done
depends on width and offset of the wheel. I have 215x40x17 on an 8j rim ET35. I haven't heard it rub on lock but hit a big enough bump I can hear it touch the arch liner - std springs on Yellow billies
L0rdMike wrote:Your front tyres are rubbing on the rear wheel are when you turn?
the side of the front tyres are rubbing on the side of arch liner,
my 18inch alloys do this at the front also, it dosent seem to have any effect of turning? but the screw that holds the arch lining on rubs the wheel which cannot be great i was thinking of perhaps re fitting the arch lining a bit further back in the arch if its possible?
"Is this possible" LOL,VERY LOUD.
Sorry, couldn't resist it
If your wheels don't scrub a little, they're not big enough
jdbecks wrote:my tyres fitted on the front are 215,45,17's and during turning rub on the black plastic on the wheel arch, the car is lowered with springs and on yellow billies,
Hi,
My son had the same problem.....his solution remove the linings!!! job done .
Regards.....Ron
Spittinflames... Forever in our heart...
3-7-08
Reached Heaven Early...
3-7-08
big_ron wrote:
Hi,
Regards.....Ron
My erm... 16's on my 106 had an issue, only the liners fell out themselves! Saved me a job though!
Hahaha Think we know what the poster means and Is referring too:- some funny replies though Profile Is everything especially If the car Is lower. The 45 profile sounds like the problem? Oh what about your rims *off set* and just how *wide* are they In Inches? As Allan has mentioned. Take a look on the reverse side of the rim.It might not be the tyres?mm.Possible with a very soft suspension under heavy cornering?Yes 35 profile works well.
Hi harry I got the problem fixed
I put some 40 profile tyres on the car and it solved the issue, the tyres on 7.5" and i cant remember the offset i think 35,
but then when I got some trade plates and drove my car to the testing station...i need to get my rear arches rolled lol...
