[Mk2] [Turbo] Iridium plugs
daiodavies
Post by daiodavies »
I have a standard rev2 turbo and i want too cange the spark plugs too iridium,which are BKR6EIX.Would i penifit by going for a colder plug (BKR7EIX) as the engine is standard.or would it not perform as well.
LiamTye
Re: [Mk2] [Turbo] Iridium plugs
Post by LiamTye »
if you have plans to up the boost or anything like that then get older grade plugs if not just use the ones you have mentioned
