Installed an S2k engine start button on my Mk2 over 2 years ago. It worked fine.
Had a Turbo conversion 1 year ago and it worked fine after that too.
I dislodged a wire when fitting my Blitz turbo timer some time back and tried to connect it back again yesterday.
I have tested EVERYTHING on my meter -
Constant live from ignition barrel = 12v
Starter motor reading on key turn = 12v
Earth = Provides 12v reading when used with above
Relay between loom and S2k button
Switched live to power switch = 12v
Earth to switch = Provides 12v reading when used with above
Wire to relay = good continuity.
Relay clicks when I apply 12v to switched power terminal.
Whats going on!!!???!!!????
Im sure the Blitz loom I connected for the Turbo timer is not causing a problem as it is only a wiring loom that sits between the main ignition harness and takes feeds off whilst allowing signals to pass through as usual.
Any ideas VERY much appreciated!
[Mk2] [Generic] S2000 starter button - it all works, but it doesn't!
Re: [Mk2] [Generic] S2000 starter button - it all works, but it doesn't!
Does it work again if you remove the loom?
That is what I am going to try.....just gotta find some time!
