Been putting my car back together after head gasket and cambelt change - and i got to the stage of putting alternator belt back on
Now should the alternator pulley spin freely by hand? If so i think mine is seized, which is abit odd as i didnt experience any loss of power before the car blew up, surely i would have felt a loss of power if the alternator was seized?
It does explain the chewed up alternator belt though
Teegs x
Seem to recall a post of Jimi's not long ago which mentioned crud & rust & stuff getting stuck between the rotor and the stator being a very common cause of this. It's supposed to be a very small gap.
About a year ago I took my alternator apart because it wasn't spinning freely & indeed the above did seem to be the case - cleaned it all up, reassembled, and it's spun ok ever since.
You're right Tegan, the altenator is seized, but based on your recent coolant explotion and the fact the car has been stood for a long while since, I would be inclined to think that the water/coolant has caused the bearings to seize.
Also looking at the belt in your other thread, it is possible that the pulley was partially seized (or not rotating freely), but still putting out enough charge not to cause an alarm.
flippin'eck wrote:Seem to recall a post of Jimi's not long ago which mentioned crud & rust & stuff getting stuck between the rotor and the stator being a very common cause of this. It's supposed to be a very small gap.
Is it fairly easy to take apart then? Is it worth doing it myself instead of buying a new one or getting it reconditioned?
Garrick - it could have been partially seized, i dont know to be honest, the belt was squealing for a few weeks before it exploded but it wasnt a constant squeal - it went away then came back.
Teegs x
I was curious as to what was inside, I can't quite remember the exact details but I had to weld some bars up at one point to prise it apart. Wasn't too worried if things snapped as I had a bunch of spare alternator parts handy.
If I'd known at the time that it could be refurbed for that sort of money I'm not sure I'd have bothered!
right dont think ill have a go myself then sounds like trouble lol - just called the parts place to get replacement and he asked me if it was a 60amp or 70amp alternator? I dont know and i cant find it in the manual - does anyone know so i can phone him back , thanks
Teegs x
Do you think the toyota dealer would be able to find out? I know they are a bit useless but im sure they have the means to find out these things?
Teegs x
just phoned them and gave him the chassis number and he said they only have options for the 70amp - so i guess its 70 amp then, i loved the prices aswell £184.22 +£30 surcharge for a recon unit
and wait for it..............£389.72 (+ vat) for a new one!
Guess ill be phoning the parts store back then lol
Teegs x
mk1 envy wrote:right dont think ill have a go myself then sounds like trouble lol - just called the parts place to get replacement and he asked me if it was a 60amp or 70amp alternator? I dont know and i cant find it in the manual - does anyone know so i can phone him back , thanks
Teegs x
im pretty sure n/a's are 70a but a toyota dealer is worth a call
I appreciate the reply - backs up what the dealer told me so that reassures me that theyve got it right
Parts store quoted me £99.90 + vat for a new one - looking at the dealer prices that seems like a good option and ill have it tomorow afternoon - is that a good price?
Teegs x
i would say camberley auto factors because they are very cheap on mk1 bits but your up in the midlands but 99+vat seems a fair price... have you tried ebay?
Teegan I have a working spare here (just of J22 of the M1). Only thing is the bolt sheared when I tried tightening the belt and the stud is left in the thread. Could be easily drilled out and re-tapped (unless you have a stud extractor kit, then even easier).
You're welcome to it for £30.00 plus your old altenator I can get refurbished
Oops wish i seen this like two minutes earlier - just found one on mr2oc for £60 delivered, hopefully it wont take too long to arrive then the car can be finished this week at last!
Thanks anyway G
Teegs x
