[Mk2] [Turbo] Pics Please....... fitting st205 chargecooler pump!!!
ELS
Post by ELS »
As titled really. Wondering if you peeps could help us out by showing a few photo's of where you securely mounted your st205 chargecooler pumps please............. :thumleft:
Benmoore999
Re: [Mk2] [Turbo] Pics Please....... fitting st205 chargecooler pump!!!
Post by Benmoore999 »
I am doing mine this week hopefully. If i get it done I will post up some pics.
Ben
raptor95GTS
Post by raptor95GTS »
ja99a fitted his in the engine bay where the carcoal cannister used to be. I think he's got pics in his profile
oBladeo
Post by oBladeo »
I'm putting mine under the bonnet to protect to :D
toxo
Post by toxo »
I've got one of these coming at the end of the month and I intend to mount it in the factory mounting location used in the Celica - on the gearbox. Can anyone think of a reason not to? I mean, if you're using the ST205 pump, and it comes with the bracket then it seems like the logical place!
ELS
Post by ELS »
toxo wrote:I've got one of these coming at the end of the month and I intend to mount it in the factory mounting location used in the Celica - on the gearbox. Can anyone think of a reason not to? I mean, if you're using the ST205 pump, and it comes with the bracket then it seems like the logical place!
I've removed celica st205 gt4 gearboxes and i can assure you the factory mounting location for the pump is not there.
Most people knock up custom brackets to enable them to mount the pump where they feel best.
I was looking for people to post up some pics of their conversions so i could look at some varied work and gain some inspiration.
So please people get posting. :thumleft:
Drifter
Post by Drifter »
Mine is situated below my apexi air filter, which Grayboy (person who i bought it off fitted) and is attached via means of a custom bracket i believe connected to the same as the apexi braket. Pump works sound hope this helps.... no pics im afraid
