[Mk2] [Turbo] Better air intake temp sensor and positioning.Results page 6.
ashley
Re: [Mk2] [Turbo] Better air intake temp sensor and positioning.Results page 6.
Post by ashley »
Sorry- but drop me a pm and I could do you one :thumleft:
Post by Martin F »
Rob - East Coast Imports wrote:
m10x1.25
Is this the size I need to accommodate the standard Mat sensor Rob ? I can just source an aluminum nut of the correct size and get it welded in the pipe I require.
Then I can block the hole and leave the rait sensor in the standard mat sensor location and bring the subject up and be able to swap if needed when the car is on the dyno, if not then no harm done....
As Jim says, Toyota put it there for a reason and I don't want to risk an expensive bill by moving it without knowing the consequences.
Thanks :thumleft:
C35Rob
Post by C35Rob »
standard sensor is M16x1.5, the triumph sensor is M10x1.25
I'd be interested to see how the person that mapped your PFC has set it up to respond to air temp readings, particularly the IGN vs air temp, as the base map isn't set to start pulling timing till 60 degrees (I've set mine lower...)
Post by Martin F »
Rob - East Coast Imports wrote:standard sensor is M16x1.5, the triumph sensor is M10x1.25
Last map was done at surrey rolling road, no idea of what has been done regarding air temps etc.
tiff_lee
Post by tiff_lee »
jimGTS wrote:bare in mind, this sensor is called a MAT sensor
a manifold air temperature sensor.
I'm sure theres a very good reason why toyota installed it where they did, as thats the temperature entering the ENGINE.
not the temp inside an intercooler pipe.
Come on mate as if the sensor being being a few inches away from the stock location would really make any real world difference in the temperature being reported back to the ECU. After all you (as in the anyone looking to do so) are already using a sensor designed for and fitted in another engine and there seems to be no major concerns about that.
The old Toyota did this for a reason argument could be applied to anything on the car, why fit after market parts/upgrades etc when Toyota fitted all the stock parts for a reason.
This replacement sensor is a good example in itself. Why did Toyota completely enclose the thermistor, why did they make it longer, why did they fit one which is slow to respond? With that last point I wonder was it a case of the technology simply not being available at the time or was it for some unknown reason to deliberately produce a smoother output as shown in the graph/image you linked? although feck knows why someone would intentionally want that in this application so I dare say it wasn't deliberate but then still it's how they designed it....
jimGTS wrote:if the car is stood still, it will heatsoak, there is nothing you can do about this and you want this to read correctly.
That's the precise reason to do something about it, if the sensor is heatsoaked it won't be reading correctly.
With that said getting away from the heatsoak issue will be pretty hard, more of a case of reducing its effect. Even with something like this
there is still going to be a degree of heat soak (ooh rubbish pun?) as you have a sensor encased in brass screwed into aluminium bolted to the manifold, perhaps if it was on the other side of the silicone joiner it would be better insulated from the heatsoak effect of the manifold I dunno but then who has that much space to mount one there (depends on setup).
I did try to find some technical data on that triumph/sagem sensor but no luck apart from this thread
http://irishrotary.com/forum/index.php? ... nsor-riat/
which quotes the fenne development ad from ebay and provides some resistance values.
Just so others can see at a glance I crudely extrapolated those values onto the resistance/temp graph for a Toyota manifold temp sensor and it looks like this
Which as you rightly said Jim (in one of your older threads I think I read it) that the resistance values are 'acceptable' iaw with the BGB.
Post by Martin F »
This is a good read and makes perfect sense.
I have just been for a nice long drive, I now have the Rait sensor.
Today the outside temps were 15 degrees, power fc reads 28 degrees when cruising around 65 mph
Parked car up for 15 minutes, came back and as soon as I turn on the ignition it is saying the air temp is bang on 50 degrees, now that figure is before I even start the engine....
So you can't even blame the air flow from the chargecooler, quite possibly it is the air temp around the sensor due to the heat from the pistons etc heating the air around the sensor however it takes quite a while to come back down. That leads me to believe that it is the sensor itself that has become hot in this period.
I am moving the sensor to see what happens, I just can't find anywhere that has an aluminum nut in stock m16 x 1.5 so I can weld it in the 45 degree pipe.
I am not going to use the throttle body because it is narrower than the chargecooler pipe and therefore needs all its space for airflow...
will update my findings when the deed is done, would be today if I could find this illusive m16 nut :eye:
tiff_lee
Post by tiff_lee »
I was thinking about this earlier and what I wrote before with regards to the OE sensor.
I was trying to get my head around the difference in speed at which the two sensors report temperature change, given that they are both thermistors so any change in temperature should change the output, it's not as if they are a digital device with a sample rate. Then the obvious struck me, one has the thermistor exposed exposed to air while the oe one is encased in brass so all the brass would need to increase/decrease in temperature hence the slower response but why do that? If late 90s motorbikes had these faster sensors then why not rev4/rev5 mr2s?
Meh be interesting to see your results, from googling it seems alot of people relocate the sensor to the cold start injector location. I would like mine of the cold side of my st205 chargecooler when I get it but I think that's going to be very unlikely due to space constraints, i'll have to assess it when I get it.
C35Rob
Post by C35Rob »
why not just use a M10x1.25 nut Martin, as it's the right thread for the triumph sensor? or are you planning on doing some back to back tests with the standard sensor?
if you can't find one, any engineering place could spin you up a threaded boss, failing that you can drill and tap a piece of ali bar stock quite easily at home
Lee: the cold start injector thing is a rev1/2 and ST185 thing - they ran mass flow management, when people upgrade them to rev 3+ (speed density) management you ditch the cold start injector and use it's redundant position to mount an AIT sensor
Post by Martin F »
Rob - East Coast Imports wrote:why not just use a M10x1.25 nut Martin, as it's the right thread for the triumph sensor? or are you planning on doing some back to back tests with the standard sensor?
I could use the one that came with the sensor, pretty sure it is aluminum, however Peter used thread lock and I don't want to force it from the Rait sensor... :-k
I have aluminum here, think I will just drill it and then thread it, what size of bit do I need buy ? or maybe i'll just say i'm looking for a bit that will make a m16 x 1.5 thread :eye:
C35Rob
Post by C35Rob »
your adapter is brass, same as mine - I expect peter made it the same as I did by drilling and tapping the brass blank I linked to on eBay.
the tapping drill size for M16 is 14mm :thumleft:
Post by Martin F »
Thanks Rob, :thumleft:
ashley
Post by ashley »
If you want an adapter made up drop me a pm, I can do it on the lathe for you :thumleft:
Post by Martin F »
ashley wrote:For M16 x 1.5 you'll do better with a 14.5mm drill, 14mm will make it difficult to run a tap through in my experience.
If you can do an adapter in aluminum that I can use as a boss and weld onto one of my pipes then that would be great, let me know how much and that would be great, cheers ash :thumleft:
ashley
Post by ashley »
Will do mate, how big do you want the outer diameter?
Post by Martin F »
ashley wrote:Will do mate, how big do you want the outer diameter?
I will send you a pm :thumleft:
ashley
Post by ashley »
Done, will post it tomorrow :thumleft:
Chumbaside
Post by Chumbaside »
Hi Ashley,
Just wondering when you'll be able to send my adaptor?
Cheers,
Mark
Post by Martin F »
ashley wrote:Done, will post it tomorrow :thumleft:
That's Awesome, it was difficult for me to source this item so you really have come through with that, well done Ashley :clap: :clap:
Hopefully i will get very different readings when it has been welded in the intake piping and away from all that horrible engine heat, very happy, Thankyou very much Ashley :thumleft:
ashley
Post by ashley »
Chumbaside wrote:Hi Ashley,
Cheers,
Mark
It's going in the post tomorrow...sorry it took me a few days to get to, struggled to get to the workshop this week- my daughter and wife have had a nasty cold :(
Chumbaside
Hey, no problem at all. :thumleft:
-Mark
