PW@Woodsport wrote:I must admit Alex i raised an eyebrow over a comment they made about Laurens car, it smacked of someone that clearly didn't know what he was talking about.
I should add i have no personal experience or prior knowledge of TDI north.
I know a lad that works there, and with TDI North being a prominent Honda tuner and specialist i wasn't expecting a call from him when he was doing a cambelt change on his civic.
They guy in question is a complete retard, it took him near on 8 hours to fabricate seat mounts to mount a bucket seat a remedial chore which would have taken any none retard a few hours to do and during so burned out many drill bits and broke 2 angle grinder discs in the process.
Also when doing the cambelt change he decided to take his air con out.
He said
"what happens if i vent the gas into the air"
"you die" was the reply sarcasticaly.
To which he proceded to vent the gas as i was running away from the car like a little girl.
Going back to the cambelt.
He though a casting mark on the block was the timing mark on the bottom pulley, So when he came to start the engine, it would turn over, not start and then fire the engine back in opposite direction.
.He couldnt figure it out and then decided to blame and annoy use when giving him suggestions as to how to fix.
Eventually at 3 oclock in the morning we got fed up and did it for him.
I guess this is not a gripe at TDI themselves and what goes on out of TDI north work hours people wouldnt really care about, but if you give a monkey a spanner, you could be waiting a while for the job to be done.
Alex
Edit: All that matters really Lauren is that your happy with the result which you have said you are so thats all good!
