jimGTS wrote:Sure
these both on meth?? You td06 one was wernt it?
Ideally I need 2000 and 2500 numbers, some graphs don't give me this but I could easily enough guess, but maybe a little more difficult to guess these numbers on your graph, lol.
I'll try, 4 gear pull again??
Ryan mentioned these 4th gear pulls generally give a little more low and mid at RS than at SRR, but I'll get them on anyhow.Shame RS don't have some sort of smoothing.
jimGTS wrote:kongaroo
done..
hard to know what to make of those, as mr2nuts dyno, same or extremely similar spec turbo, low and mid is WAY different to yours.
Kongaroo wrote:Hey Jim, any chance you can put my TD06 and GT28RS graphs up for a little while so I can have a quick comparison for my own interest like you did for MR2nut?
Green is TD06 at 21.2 psi, red is GT28RS at 22psi:
http://i716.photobucket.com/albums/ww16 ... verlay.jpg
Kongaroo wrote:Simple answer is: My mapping Kung fu is strong![]()
I'm joking of course but that's not say I didn't spend quite a while experimenting with the map in a number of ways to improve spool up.My TD06 map was also the result of many months of tweaking and experimenting too before going to the dyno for the final adjustment and power figures.
The number of different map save files and experimental mapping notes saved on my laptop from my road mapping is now quite sizeable after the last couple of years.
I think if both maps hadn't performed as well as they did I would have been disappointed in myself after all that effort, lol.
My mod list is listed in my garage but the answer comes down to a number of things.
At around 3K RPM I already have around 16psi boost if you look at my boost vs power graph.Assuming the relevant load cells have been mapped appropriately having 250ftlbs flywheel torque at 16psi on a GT28RS is not difficult.
Especially when you consider what the flywheel torque of a bog standard rev 3 car to be at just 13psi
(can't remember the exact figure but I believe it is over 200ftlbs at flywheel).
Part of the reason why the GT2876r sort of gets owned all across the rev range by the GT28rs is down to it having a poorly matched turbine to compressor wheel.This results in poor turbine efficiency that kills spool.
Effectively you end up with the similar restrictions in peak power of a GT28rs but without the fast spool.
Another reason you guys have already answered which is I am running upgraded cams and intake manifold which give me more top end.
In fact my 250ftlbs at flywheel at 3K rpm is very similar to what Bruce achieved years ago on his Gen 2 in the US.I believe he achieved 200ftlbs at the wheels at around 2900rpm with far less VE mods than I have now.
Regarding the differences in my TD06 results vs MR2nut's GT2876r- read post 54 on this thread:
http://www.mr2oc.com/showthread.php?t=381850&page=2
I summarised ATS Scott's findings on his car between the GT2876r and his TD06 and then noted my own which were very similar.It's due to results like this that the Americans have been saying the GT2876r is a mismatched turbo for many years now.
Don't get me wrong- I'm not trying to criticise your choice of turbo but just trying to answer your question.
Hopefully this won't turn into a slanging match, lol.
jimGTS wrote:Who knows, but that graph shows it anialating every other graph in the table till 4-4.5k, lol.
Didn't think it was possible to be making 300lb at 3.5k rpm, lol.
Kongaroo wrote:For myself I wouldn't mind maybe another 30 to 40BHP or so just to give the car the edge against some of those big V8 cars![]()
