PK_090'S Build/bodge and restore thread!
pk_090
Re: PK_090'S Build/bodge and restore thread!
Post by pk_090 »
Yes and expensive too....i could spend a lottery win in that shop.
Alex
platmatt8 wrote:Lauren has got bigger balls than most men on this site
charged wrote:Mine's probably screaming 'stop raping me' :D
SuperRedMR2
Post by SuperRedMR2 »
And then you'll find that you could of got most of the parts cheaper elsewhere!
pk_090
Post by pk_090 »
Yeah probably sods law tho isnt it.
LimeyMk1
Post by LimeyMk1 »
Most of the parts? I think you can get all of the parts cheaper elsewhere. :lol:
I've got nowt against the guys there, they're a sterling bunch but their prices could be a bit more competitive IMO.
pk_090
Post by pk_090 »
Ok well a little update. I ordered new big end bearing shells to replace also, and when refitting, they simply wont fit. I used Tom's method of determining which shells to use ordered them and the wont fit, i rechecked my numbers, Toyota checked theirs and sent me new ones and these wont fit. Any advise or pointers?
Alex
SuperRedMR2
They are too loose or too tight?
elbon50
Post by elbon50 »
I understand that there are two crankshaft journal sizes Alex
However, if the crank has been re-ground at some time you will need undersize shells
Do you have access to a micrometer to measure the journals :?:
What markings are on the back of the shells that came out :?:
Peter
Icsunonove
Post by Icsunonove »
The crankpin diameter is a nominal 42mm, so it should measure something between 41.985 - 42.000mm. If it is 0.25mm under this it has been reground.
pk_090
Post by pk_090 »
haven't measured it yet will hopefully be doing some more work on it tomorrow morning. If the crank has been re-ground where do i get oversize ones from?
Alex
SuperRedMR2
Toyota
pk_090
Post by pk_090 »
Ok, ill get on this hopefully tomorrow morning.
elbon50
Post by elbon50 »
pk_090 wrote:haven't measured it yet will hopefully be doing some more work on it tomorrow morning. If the crank has been re-ground where do i get oversize ones from?
Alex
There will be markings on the back of the shells to show if they are undersize Alex
This may seem irrelevant but are there oversize markings on the piston tops :?:
(If so that gives a clue about whether the engine has been previously re-conditioned)
Peter
pk_090
Post by pk_090 »
Well rang the enginebuilders that did the machining for me, they have had the rods and everything back and sorted the issue out this morning. he says they were the wrong ones. He s got hold of the correct ones and sorted this out now. Hopefully there will be no more snaggs...fingers crossed.
Alex
elbon50
Post by elbon50 »
pk_090 wrote:Well rang the enginebuilders that did the machining for me, they have had the rods and everything back and sorted the issue out this morning. he says they were the wrong ones. He s got hold of the correct ones and sorted this out now. Hopefully there will be no more snaggs...fingers crossed.
Alex
Why did the engineeering company have the rods Alex :shock:
They didn't need them
Are they marked ? So they go back in same bore as originally :pale:
Peter
Icsunonove
I really can't understand all the confusion :?
Looking back at this:
It appears the big end bearings are part number: 13041-16071-0X where X is the class.
pk_090
Post by pk_090 »
Aparantly i just sent him all bottom end parts. He said toyota had sent ones for a completely different engine as they were completely miles out. All sorted now though!
Alex
pk_090
Post by pk_090 »
So the bearing nightmare has now been sorted. At the weekend have just started cleaning and sorting some parts out, have cleaned all the sump from all the sludge that was in the bottom, have cleaned and lubed up the tvis manifold as these were crudded up and looked like they were starting to seize up so soaked and then wd40'd, have then pained the cam covers red with white lettering! not bad for a saturday morning!
Alex
elbon50
Post by elbon50 »
pk_090 wrote:So the bearing nightmare has now been sorted. At the weekend have just started cleaning and sorting some parts out, have cleaned all the sump from all the sludge that was in the bottom, have cleaned and lubed up the tvis manifold as these were crudded up and looked like they were starting to seize up so soaked and then wd40'd, have then pained the cam covers red with white lettering! not bad for a saturday morning!
Alex
Beginning to make a little progress now Alex :)
Goody good :thumleft:
Peter
pk_090
Post by pk_090 »
Hopefully going to get the cam gears and other pulleys to give a wire brushing and maybe a lick of paint also. Seats and harnesses are ready to go in when the car gets home, and also the sound deadening and carpet will be removed. Friend of mine has bought an omp dished corsica "style" steering wheel £40 delivered so im waiting for him to get that for me to see the quality and decided whether im going real wheel or get a good quality knock off.
elbon50
Post by elbon50 »
pk_090 wrote:Hopefully going to get the cam gears and other pulleys to give a wire brushing and maybe a lick of paint also. Seats and harnesses are ready to go in when the car gets home, and also the sound deadening and carpet will be removed. Friend of mine has bought an omp dished corsica "style" steering wheel £40 delivered so im waiting for him to get that for me to see the quality and decided whether im going real wheel or get a good quality knock off.
Are the water jacket & oil galleries thoroughly cleaned out Alex ?
Peter
