Hi all,
The sysmtoms are very reminisant to fuel starvation under load.
Even though you have an uprated fuel pump/regulator, the ECU is sensing a rich mixture situation caaused by excessive fuel demands due to the high preset boost setting.
Because of the latter, the ECU can't meet the demmand, maybe due to a restricted air intake volume, so then the ECU leans off the mixture, and this is detected by the knock sensor, hence the error codes.
The power will then suddenly drop off, the revs will drop, and with the now reduced airflow, the engine off boost, the ECU then senses normallity and the cycle starts.
As was suggested, fit a MBC and set it to approx stock level, and you may find the car runs fine, although not with the previous performance, but at least stable running.
I agree that the EBC
"Could
??" be the trouble.
Food for thought, if not tell me to shut up
