![Pray :pray:](./images/smilies/eusa_pray.gif)
2mad wrote:Ok, still got my fingers crossed.
good luck mate
sheppy wrote:2mad wrote:Ok, still got my fingers crossed.
good luck mate
Same here man, totally hacked off with it to be honest, might just chuck it in the garage for winter
2mad wrote:sheppy wrote:2mad wrote:Ok, still got my fingers crossed.
good luck mate
Would make it easier to work on the car.
weathers not getting any better
dont get disheartened mate
Project gtx.
wooo
sheppy wrote:I know man, the car has been as good as gold the whole time i've had it.The new owner of the blitz has told me his car is running fine with it on, also, when i met you guys in Edinburgh, i tried Ians ecu on my car and it ran perfect, so wiring is fine.
The next day i put the duffer ecu on simply to move the car in and out of the carwash and it got progressively worse running until it wouldn't start at all.
I'm absolutely certain the dud ecu has caused the problem
(bearing in mind it had some kind of chip/box attached to it).
The only thing in the ignition system the ecu talks to is the igniter, however the black box may have talked to the map sensor.
I'll have a proper look at it o.
Tuesday, vsry frustrating as i want to just start chucking my cash at project gtx
sheppy wrote:I've maybe miscommunicated what has actually happened, this is the order the ecus went on and off.Blitz off
(before i sold it)then dud ecu on, realises it doesn't work, blitz ecu on.
Car runs perfect.Working rev3 ecu on for test.
Car runs perfect.
Sold blitz so ships it off.
Puts dud ecu back on to move the car 6 feet, car stops running/starting.
Working rev3 ecu turns up, car still doesn't start.
Messes about with plugs etc, manages to gete car to splutter into life, drives it home but doesn't run great.
Won't start the next day and hasn't since
Torero wrote:I feel for you Sheppy.I hope you get this sorted and quickly buddy.
