jimGTS wrote:mr2nut123 graph plotted!
Cheers Jim.
![Wink :wink:](./images/smilies/icon_wink.gif)
Moo wrote:Could you add mine please Jim? Cheers.
Stock rev3 turbo engine, ct20b, st205 cc, bolt ons, stock ecu, 1.1 bar.
http://i78.photobucket.com/albums/j93/M ... C00038.jpg
http://i78.photobucket.com/albums/j93/M ... C00039.jpg
jimGTS wrote:I don't disagree, lol, however from what moo has experienced, am pretty sure his butt dyno says there is a difference from when that first dyno was
done(year plus ago) and dd.
Better cc pump, rad and all.
So is probably more of a difference if anything.
But who knows.
Anyway, I'll try and get these all uploaded soon.
Kang, you want your results up there?
You dynoed at srr to right??? Unless I'm going mad and there up there already?
Kongaroo wrote:jimGTS wrote:I don't disagree, lol, however from what moo has experienced, am pretty sure his butt dyno says there is a difference from when that first dyno was
But who knows.
Cheers for the offer Jim but my car was dynoed at RS tuning so I don't know if you'll allow mine up there- although it was done in the appropriate shootout 4F mode.
But if you're up for it here's my self tuned TD06 with cams, upgraded intake manifold and methanol injection:
http://url150.imageshack.us/url150/6770/1fwhpfwtq.jpg
The last 4 runs were all at the same boost controller setting but with minor adjustments to fueling after each run.Peak boost was 21.2psi on the final and most powerful run
(that's the red coloured line although you may find the 417BHP run denoted by the light green line easier to trace on the scan).
The 3 runs prior to this were all at 21.1psi peak boost
- ie.
the 417, 412 and 411BHP runs.
Regarding the differences between the Dastek and DD.As mentioned earlier I didn't see much difference when comparing the WHP numbers between the 2 dynos.
I recall making a mental note that the Dastek was higher by about 10WHP at the 320 to 330WHP level.
I worked this out by comparing to the numbers I was seeing on my Blitz power ID which is very consistent when you know the exact weight of your car at a particular fuel load.Incidentally this is how I measure changes in power when I map my car on the road as my own butt dyno can be unreliable, lol.
What I did find was that the Dastek dyno seemed to give me higher peak boost figures than I achieved on the road on the same boost controller setting whereas the DD dyno gave me lower peak boost figures than on the road when run in shootout mode.This probably means the Dastek that I used applied more load on its dyno runs than the DD in shootout mode.
Some geeky dyno trivia there for you
(PS
- sorry for going a little off topic)
mr2nut123 wrote:Which gear were your runs done in by the way?Impressive figures
RyanRs wrote:pete, what shortblock combination did you use to get 2.190L? are you using a 5sfe block?
