Rogue wrote:All of the engines in Lotus cars are available in Toyotas.
Would that extend to the Lotus ECU e.g.
MartG wrote:Would that extend to the Lotus ECU e.g.the one in the Exige 260 gives a lot more power than the Toyota one
Quigonjay wrote:does the 150/200/250 refer to the power to weight ratios?
cartledge_uk wrote:Just out of interest, how much are the dataloggers in relation to Demontweeks(£499-648+vat) and which Hz is needed, I presume the basic one?
And are there hire options in place for them?
MartG wrote:How extensive are the allowed bodywork mods- e.g.
if someone turned up with an engine lid like this one
Rogue wrote:kaiowas wrote:You might need a minor exception for the"No modifications to suspension pickups" for certain mk1s.
Pre Aug 86 the front top mounts only had 3 mounting points, later cars have 4.
With the control coilovers being advertised as suitable for 86-89 cars I'm assuming they have 4 bolt top mounts and therefore will not fit an earlier car unless a 4th mounting point is drilled.
Good spot.The controlled suspension kits will not be the same as the retail kits
- they'll be particularly valved and sprung for race use.
It shouldn't be a problem to have a specific top mount made up to suit early cars but I will double check.
karldavies wrote:Excuse my ignorance Patrick, when would this SuperGT series start? I'm just trying to guage whether of not I could get everything done in time.
karldavies wrote:Also mine is a t-bar model.Do you offer a service whereby i can get the panel's welded.
karldavies wrote:Lastly, I have just fitted a set of tein lowering springs.Am i able to buy the coilovers at a reduced price without the springs?
bri0905 wrote:Am I right then, as a bare minimum we'd need an approved cage(I.e from rogue) an fia approved seat and harness, the regulation coilovers and r888 tyres
And the datalogging kit?
Just asking as my budget is quite small but I really want to try anyway?
