Alex
platmatt8 wrote:Lauren has got bigger balls than most men on this site
charged wrote:Mine's probably screaming'stop raping me'
pk_090 wrote:so its going to have pretty much new everything apart from pistons crank con rods etc etc, but im looking forward to putting it back together and seeing what a differance its going to make! Im still in need of a crank pulley as mine snapped coming off.Was speaking to fensport last week asking if they have any n/a billet ones and they said there is a batch being sent off to be balanced so might get one of those.
Also pondering a ebay short shifter and a boss so i can put my momo wheel on.
Alex
pk_090 wrote:yeah im glad im going to have a strong engine that hopefully(touch wood) wont break again.
Next when i have money again i think is definitely going to be on suspension and handling.
At least going to look at coilovers and poly bushes, maybe move to 15" wheels better brakes and maybe look at carbon items to save weight.
Alex
pk_090 wrote:Yes peter i have been.Havent bought much in the way of anything but engine parts, im up to about
£650 in parts and
£200 from the machinists, not including the pulley from fensport when they are in stock.
Should hopefully start building back up this week hopefully should be back up and ready for sat 18th for the trackday at oulton, ive givern my place to my mate so he is going on track in his car so im just aiming to drive there in the convoy with everybody else i know that is going, that is the target!
Hopefully will take some photos of where i am up to tonight and will upload later!
Alex
pk_090 wrote:Some more photo's! Apologies to non facebook members!
http://www.facebook.com/media/set/?set= ... 593&type=1
So the block and head have been skimmed, the head has been pressure tested, valves re-lapped with new oil seals.
List of parts so far.
Gasket kit, oil seals, piston rings, head bolts bearing journals and bearings, water pump, thermostat, cambelt and idler pulley, new crank pulley as mine snapped coming off, distributor arm and cap(has new leads by the look of it when i bought it) plugs, oil filter and of course fluids.
I may have missed things off this list.
Alex
