Thanks Peter for the information.
When there is no way to verify the authenticity of information like this, as an engineer there are many tools to give very good estimates
From your info:
Rev 1
1215Kg
158BHP
Theoretical values are
(your values in brackets() and toyota's values in
Power at Flywheel
(BHP)
158
Weight without Driver
(KG)
1215
Power to Weight Ratio
(BHP Per Ton)
132.13
0
- 60
(Secs)
7.90
(6.7)
[7.8]
0
- 100
(Secs)
23.09
(18.
60
- 100
(Secs)
15.19
Quarter Mile
(Secs)
16.34
Terminal Speed
(MPH)
84.12
Drag Strip Quarter Mile
(Secs)
16.24
(15.2)
Drag Strip Terminal Speed
(MPH)
85.09
(92)
Rev 2
from your info
154BHP
1305Kg
Power at Flywheel
(BHP)
158
(KG)
1305
(BHP Per Ton)
123.02
0
- 60
(Secs)
8.44
(7.4)
0
- 100
(Secs)
25.28
60
- 100
(Secs)
16.84
Quarter Mile
(Secs)
16.88
Terminal Speed
(MPH)
81.71
(Secs)
16.78
(MPH)
82.64
Rev3
174BHP
1305KG
Power at Flywheel
(BHP)
174
(KG)
1305
(BHP Per Ton)
135.47
0
- 60
(Secs)
7.72
[7.7]
0
- 100
(Secs)
22.08
60
- 100
(Secs)
14.36
Quarter Mile
(Secs)
16.15
Terminal Speed
(MPH)
85.52
(Secs)
16.05
(MPH)
86.50
The calculator can be found here
http://www.letstorquebhp.com/calculator.asp
Now you can argue what you like, but the calculator puts things a bit logically
all three cars are similar, only difference is basically power to weight ratio, and one can clearly see that at least in theory the 0-60 times should be
Rev3 7.7
Rev1 7.9
Rev2 8.4
And if I look at our resident MR2
expert
Rogue wrote:
Official Toyota figures for revision 1/2 0-6 is 7.8 seconds, versus 7.7 seconds for the revision3.
The difference is fairly marginal between the two, but it is there and the balance of power is in favour of the revision 3+ engine.
Just check out the MR2 Challenge grids for the mk2 and you'll find all of the front runners use revision 3 engines.
Patrick
These 2 values are spot on with my theoretical estimate.
I personally will not agree with the value of 6.7s as in my opinion/feeling
(i might be wrong) there is a high possibility that whoever did the timings mistakenly entered 7.6s as 6.7s.
I come to this personal conclusion as the 1/4 mile doesn't show the same improvement in performance over the factory or theoretical values.
And for comprehensive values of figures from other sources
http://www.megaboost.co.uk/mr2/frames/techinfopage.htm
I personally will go with logical thought process than just simple trust, but hey that is my nature.
Please don't take this personal, but I just like to discuss this technical point folks
