To answer Jim, i believe #4 cylinder being furthest from the water pump and the design of the coolant jackets in that area lead to hotter block/head temps at that end of the engine, there is a theory that there is also an electrolytic erosion going on between the aluminium and iron combined with weak antifreeze concentration in the coolant producing a "battery" type effect which eats into the block causing the deep pitting found around number 4.
How true that is i don't know, but something is causing the blocks to be eaten away around #4 coolant jacket and they definitely run hotter at that end.... all interesting stuff.
Good news & Bad News ??
Re: Good news & Bad News ??
elbon50 wrote:oukie wrote:Blacktop FTW
Edit, Peter did you ever use those cams and verniers I sold you.
If not you wanna sell them back maybe
Depending how it goes Chris, if I don't need the cams & verniers you'll get first chance to have them
Great, pm me if and when.
Mk1b White T-bar SC 1987, Mk1b White coupe Jan90, Mk1b White coupe Jan90 (spares), Mk1b Mica blue T-bar Mar90, Mk1b Mica blue T-bar,full climate control,Jan90, 5 mk1's
