JD wrote:Bob if you have the time to go into detail, I'd be interested to read about some of the setups you've built over the years and how these worked, because you keep dropping tidbits of info without ever really expanding on it. I do understand what you are talking about.
For instance, where would your injection points be if injecting separately? Pure methanol before the throttle plate and water directly into the manifold? That would seem to make sense based on what you've said. I don't suppose many people with road cars would like a tapped tank of pure methanol in their cars. So, for road cars, it is safer and more practical to inject together, so methanol can both cool the intake charge and increase octane, and water can provide additional cooling in the cylinder when evaporated there at higher temp?
The manifolds we use are "dry", they are not designed for a fluid to flow through them, so the distribution will not be very even.
To give the correct amount of water or methanol they need to have one injector per manifold runner.
Anything that you inject into the manifold will displace air, but what we are after is more air not less.
Water will absorb a very large amount of heat, it does so in the cylinders but in the manifold there is just not a large enough difference in temperature between the water and the air. It also has only fractions of a second in the manifold to do anything, just no enough time.
So with water it needs to be injected as close as it can be to the inlet valve.
With methanol it will absorb heat at a much lower temperature differential and much quicker, cooling the charge, this will increase the airflow in the manifold.
So Methanol should be injected right at the top of the manifold runners.
Now because methanol is a fuel the engine will be running a richer mixture, and even more so if it gets on to the IAT sensor as the ECU will also put more fuel in as it thinks it has more air.
With the JDM turbo engine cars we have most of the time they are running under the control of the knock sensor, you will not know that, it is all auto control by the ECU.
Put a water injection system on and you may well feel a boost in power, because there will no longer be knock and the ECU can go back to its design ignition timing and a/f ratio.
Put water into an engine without knock, because it will have reduced the temperature and therefor the combustion pressure the power will be reduced.
