Peter Gidden - SBITS wrote:MR2 Rich wrote:bobhatton wrote:
Because by adding high octane fuel or installing lower compression pistons the engines then start to perform the way they should do, See jimGTS post above.
Still waiting for some evidence that lowering the compression ratio makes a engine perform better...
What do you mean by evidence?
Will Garrett's word do?
http://www.turbobygarrett.com/turbobyga ... with_boost
you are taking what he is saying out of context, he is suggesting properly intercooled mr2s are not retarding ignition from knock (as they are not overly knocking) and so will perform better then at lower CR, he is merely asking for back to back dyno or some other evidence of the low C/R vehicles vs stock C/R
he is in agreement with garrett quote 'Generally, compression ratio should be set as high as feasible without encountering detonation at the maximum load condition'
