gavsdavs wrote:IanParkhouse wrote:there's a tendency to plough straight on
Understeer on exit to the corner..
.this sounds like you haven't completed the corner yet, the power unweights the fronts and will indeed charge straight on.
I do something similar myself- never realised until someone pointed it out.
You spend a lot longer waiting for the car to if you're pushing the front through the corner.
I wouldn't put this down as a'problem' with an lsd
- it's just slightly better at getting equal drive to both sides.
Are you sure an equivalent car without an lsd would behave better
Its only really at the limits of traction you will see a difference in car behaviour with/without LSD.when everything is grippinng, they are largely invisible.
I'm glad someone else touched on this.
