Keljon wrote:any more updates to the build thread, 25k including donor car?
I've been keeping the blog up to date, as it was easier and allows me to easily get all the pictures I need at the end to show an amateur build.
http://miamigt4kitcar.blogspot.co.uk/
£25k is the lot to be on the road in my view, so everything below;
Buying kit, Delivery of kit
Donor car
- keep bits wanted, shot blasted and powder coated relevant bits.
Engine work
(metal headgasket etc.
New parts
- all bearings, bushes, tie rods, radiator, fans etc.
Spraying of the car
wheels
- second hand potentially although will of been refurbished.
If not the price will increase slightly for the right wheels.
Realisticly cheapest it could be done is around
£20k minimum then spend bits getting to higher standard over time, however if you can import via a VAT registered company you'll save a couple of K there.
.something I couldn't do unfortunately!
