KarlBristol wrote:Track times simply cant be used prove that, and have no constant measurable bearing on aerodynamics as there are far too many variables involved in a track day
If you want to measure results of aerodynamics the only proper way is by an air tunnel or similar.
Otherwise its just finger in the air stuff.
Oh and Im not nieve regarding driving at speeds and how conditions alter this.
I am a fully trained Police advanced driver.
If you follow F1 you will hear regularly that teams see discrepancies between their track laptimes and what their wind tunnel says.
Whilst the wind tunnel is typically more reliable, even the best ones to not represent the real world with 100% realism.
And at which point during your training did they teach you about extensively about aerodynamics, the quantifyable effects of weather on lap time and experimental measurements and data analysis?
KarlBristol wrote:Out of interest
- what are future plans regarding the car?
More aerodynamic work or going to aim for engine mods etc.
Have you considered getting rid of the passenger wing mirror all together and changing the driver one for a more aerodynamic version?
Any plans for a different front bumper as well to help get the air over the top of the car? It all adds up
I want a set of semi slicks and then I'm done.
No interest in engine work, its plenty powerful.
No interest in further aero work.
Im keeping the wing mirror as I drive the car on the road.
I'm sure it all adds up but I cant afford those things and they are bad on a cost benefit analysis.
niks wrote:run an A-B-A test.
Next time you enter a trackday, first do a couple of fast stints with your aero mods on, then simply remove them where possible(might take some effort!) and run again.
Finally, bolt everything back on and repeat the initial test to be able to track lap time delta due to track evolution, ambient conditions etc.
Another point to think about: your laptime gain might not simply be due to an increase in down force, but possibly an improvement in car balance giving you more confidence to attack corners and carry speed in.
Anyway definitely an A for effort there mate!
What data logging are you running?
Thats certainly an idea and yes that would show a good back to back reference.
But considering to do as you have suggested would take about 4 hours, which is 4 hours of wasted track time, thats not gonna happen.
In fairness I never said anything about downforce.
I never actually thought my modifications would add any significant downforce, rather that they would remove the lift the car creates due to its bad design.
Aerodynamics is as much about balance as it is downforce.
If the balance has improved then the aerodynamic mods work, where the aim was to improve laptime, not downforce levels.
Thanks, i'm using a racelogic driftbox.
Not entirely true.
The venturi effect is a near drag-less effect.
This is what is seen on the underside of the car.
Also the modifications I have done will have streamlined the car in certain areas.
The post radiator modification, the flat floor, diffuser and the engine lid all make the car less draggy.
The front lip, canards and rear wing make it more draggy.
The weightings of each are hard to know.
Also if the aerodynamics facilitate faster cornering speeds then the speed achieved at the end of the following straight is often higher.
