Project MRX350
dawesy
Re: Project MRX350
Post by dawesy »
looking good :thumleft:
PW@Woodsport
Re: Project MRX350
Post by PW@Woodsport »
Thanks mate.
Work continued today on the arches, i finished off one of them that now only requires high build primer and painting...
I also got the OSR arch fibral'd ready for final filler...
The NSF arch has had its secondary fibral skim to get the basic profile right, lots more work to do here however...
PW@Woodsport
Re: Project MRX350
Part of my excercise in building my ultimate "useable" Mk1 is giving it a big brake upgrade, not just for performance reasons though, my stock brakes were excellent, but i've had a lot of experience fitting big calipers to Mk1's in the past with great results.
I did consider a few options, including Keri's excellent WMS kit, but my budget wouldn't stretch that far and i need to spend in other areas.
So armed with piston specs, master cylinder displacements and my best guess i've come up with the following combo.
I've bought some Aston Martin V8 Vantage rear four pot Brembos, the piston size and caliper size is just about perfect....
Now to get these working behind my Borbet wheels is no easy task, i have 45mm to play with between the stock disc face and the back of the wheel spokes, the Brembos are 60mm from their disc face to the outside of the caliper, so i needed 15mm from somewhere. It is not possible to fit spacers because my arches are already done.... poo.
So i set about researching discs, finding one with 15mm more offset inside the hub to take the disc inboard enough to both clear the caliper mounting point and also give me that extra spoke clearance. In the end i found some Range Rover II 2.5 TD (94-02) discs that are pretty much perfect. They are 297mm diameter, 25mm thick and will place the caliper in the right spot with mm's to spare.... awesome.
The only mod i need to do is drill the 4x100 PCD into them and have some spigot rings made (70.0mm OD, 54.1mm ID, 5mm thick), after that i'll make some caliper brackets, pretty easy being radial mounted ones, done this loads of times before.
I'll also be going for Goodridge hoses, Renault 5 turbo ones to be exact, they're perfect for calipers like this.
PW@Woodsport
Re: Project MRX350
Today was spent doing more arch work, i end up looking like a cocaine dealer that's had an accident but it's a necessary evil to get the job done. Lot's more profiling to get the arch flowing nicely into the front lip but it's starting to take shape.
A few more weekends of this and it'll be ready for some high build primer and then paint.
stenky
Re: Project MRX350
Post by stenky »
PW@Woodsport
Re: Project MRX350
Bank holidays are effing marvy aren't they?
This morning i have mostly been doing the Woodsport crystal sidelight/indicator mod.
I showed a few of you these little beautys at JAE last year, we all know about the clear lenses you can buy from Toyota but it always bugged me that you can get nice crystal side repeaters but nothing to match the front, the opaque bathroom shower door look of the "clear" lenses is not clean enough for this build, i wanted something new looking and fresh.
So, i had these custom made, proper divided housings with sidelight and orange indicator bulbs, glass fronted lenses, none of your plastic here oh no! Metal bodied surround and a custom bracket, they cost a fortune to do but hey ho i'm a Mk1 nutjob and <flicks hair> ..... i'm worth it.
Woodsport crystals...
They are slightly smaller than stock, i wanted to narrow the bumper apeture with this mod, to make them slightly less understated... the devil's in the detail and all that crap. When it's flushed over and painted the bumper will look stock to the uninitiated.
Designed to compliment these repeaters...
Clears Vs Woodsport Crystals...
The crystals mocked up....
And with the apeture modified with its first stage of Fibral...
I like this..... a lot.
kevin..in
Re: Project MRX350
Post by kevin..in »
PW@Woodsport wrote:Bank holidays are effing marvy aren't they?
ditch the orange bulb for some silver tech ones and that is just the coolest mod ever Paul (I may have exaggerated a bit here!) very nice though
PW@Woodsport
Re: Project MRX350
Silver tech ones? Please explain young Jedi, i'm not familiar with those?
kevin..in
Re: Project MRX350
Post by kevin..in »
PW@Woodsport wrote:Silver tech ones? Please explain young Jedi, i'm not familiar with those?
they have a silver coating but flash orange, look better than the fried egg appearance of an orange bulb in a silver reflector, a cheapskate option is just to mist spray your orange bulb with silver paint, but proper bulbs are available
OMG I'm teaching the master :whistle:
apparently its silvatec! #-o
http://www.ebay.co.uk/itm/Chrome-Silver ... 2c5fc5be2e
http://www.halfords.com/webapp/wcs/stor ... yId_165688
kevin..in
Re: Project MRX350
Post by kevin..in »
now some proper clear/crystal rears and i'm reaching for my wallet :thumleft:
PW@Woodsport
Re: Project MRX350
Awesome stuff, i'll get some of those bought, cheers mate.
Oh, crystal rears would be a little too Lexi for my taste but i could have a look and see what i can do.
kevin..in
Re: Project MRX350
Post by kevin..in »
PW@Woodsport wrote:Awesome stuff, i'll get some of those bought, cheers mate.
just the indicators and reversing lights not the stop/tail lamp, i recon it would look good
as the lenses come apart it shouldn't be a major job to replace lenses & reflectors
Re: Project MRX350
Awesome developments fella, love your crazy project threads! :mrgreen:
Would love a set of them arches and wings at some point =P~
PW@Woodsport
Re: Project MRX350
Thankyou kind sir. :thumleft:
jimi
Re: Project MRX350
Post by jimi »
You mean similar to this
:D
kevin..in
Re: Project MRX350
Post by kevin..in »
:D
while I love the ingenuity of your mod Jimi I would love proper automotive quality lenses, kind of robbing your idea but taking it to the next level.
PW@Woodsport
Re: Project MRX350
Spent more time on the WS crystal sidelight mod, almost finished the bumper apertures now, i think it'll take a keen eye to spot they have been modified once painted.
Working on the last of the wheel arches now along with the sideskirts, not long before it sees some paint.
boondougal
Re: Project MRX350
Post by boondougal »
looks great Paul, liking those lights, they will look completely factory but just a little more bling!
PW@Woodsport
Re: Project MRX350
Thanks Sam, it's one of those projects were you don't see the overall look of the car until it's painted, very happy with it so far though, really need to get those coilovers onto it, get it dropped by about 20mm.
PW@Woodsport
Re: Project MRX350
All four arches are now in high build primer, this is just the first coat, it will take a few hours of wet flatting and more high build before it gets the desired finish and then i can concentrate on the top coat.
Front modified indicator recesses now primed, i can see these still need work but pretty happy so far.
So a few more weekends of this and it should be ready for paint.
