Yeah im getting the clutch done at the moment and I think the oil needs changing.
At the moment in reverse it makes a bit of low tone screeching noise
TRD 2000GT wrote:Around tight corners it will clunk pretty loud- Everyone who has seen me take roundabouts or corners can see it lock then unlock.
Make sense?
Lauren wrote:TRD 2000GT wrote:Around tight corners it will clunk pretty loud- Everyone who has seen me take roundabouts or corners can see it lock then unlock.
Make sense?
Plate type lsd as J&K said.Mine used to lock up very easily at slow speeds
and you could feel it wind out when pulling away from T-junctions etc.
Never had any probs with it actually locking up round roundabouts, so maybe you've got a really tight LSD in there?
Yep thought that rev2 was plate type rather than viscous hence my reply about wheels going in the same direction.
MegatronUK wrote:
The rev2 onwards uses the later gearbox so it has the same LSD as the rev3;i.e viscous coupled
(this is the version with the hexagonal bar when you look through the gearbox).
It's the rev1 with the earlier gearbox that has the plate diff
(this has a small circular hole through the centre of the gearbox; whereas the non-lsd is clear all the way through)
- but it doesn't seem to be very common, unlike the later boxes.
Unfortunately mine is broken at the moment..
but while it was working it did seem quite aggressive and it certainly did donuts no problem
Drshifty wrote:I've always wondered about mine, its a rev 1, it clunks quite alot and feels pretty planted at the back all of the time.
Certainly if I boot it up the gravel road I live on then I get two straight lines about twenty odd feet long does that suggest its got a slipper in it?
jonb- wrote:
Strangely, I thought my rev3 had the standard LSD but today I jacked it up and span one wheel.After a small amount of free play i felt a clunk and the second wheel started spinning the same way.
Anyone want to take my gearbox off and find out what diff i have?
Snap.I thought my rev 3 was standard, read through all the posts etc, but indeed, when you jack it up and spin one wheel, there's a bit of free play, then the other goes the same way.
Let me know if you work out what's going on!
If it does goes the same way then LSD.Put it this way, open diff cars will always turn the other wheel in the opposite direction.
Thought from what others ahve said this only worked on plate type LSDs?
That was both Jon's and my point.
We both
(think we) have standard rev 3 diffs, which are supposed to be viscous.
Opinion seems to be that viscous diffs will behave like open diffs if you jack the back of the car up and try turning the wheels
(ie turn in opposite directions), but we see them behave like a plate LSD
(ie both wheels turn the same way).
There's no question of whether we've got LSDs or not, just which type.
We both
ExactlyI've no other symptoms to suggest i've a aftermarket diff in there, no clucking or skipping at full lock etc.
Perhaps the general opinion that the vicous diff fails the'diff test' is incorrect, though that said i get the theory.
skinthespin wrote:Can I just throw something in that worried me regarding oil, there are gearbox oils and LSD oils, LSD oils sould not be used in an MR2 gearbox even one with an LSD as these are designed purely for differentials, not gearboxes and are much thicker(or thinner, cant remember which!).
The MR2 LSD is inside the gearbox and as such was designed to run on the gearbox oil.
Im sure someone will correct me if they think im wrong..
