ABFlug Style Arches Group Buy Thread
Forum For IMOC Group Buys
CarBen Fibre Creations
Re: ABFlug Style Arches Group Buy Thread
Post by CarBen Fibre Creations »
1. hmmmmm (jeroen) / 1 set / TwoBrutal
2. Davis / 1 set / MR2OC USA
3. sw22 / 1 set / MR2OC USA
4. Mrtwoben / 1 set / MR2OC UK
5. Dumbizzle/ 1 set/ MR2OC USA
6. IchEAtedMyWiFeY/ 1 set/ MR2OC USA
7. Signori / 1 set / IMOC
8. slipping clutch / 1 set / IMOC
9. blue92mr2/1 set/ MROC USA
10. Scotty1982/ 1 set/ IMOC
11. gtfsniper / 1 set / MR2OC USA
12. craig_mr2_mk1 / 1 set / IMOC
13. bluesmoke / 1 set / MR2OC UK
14. karldavies / 1 set / IMOC
15. stevegts / 1 set / IMOC
16. AlexSW20 / 1 set / IMOC
17. masruque1 / 1 set / MR2OC USA
18. bri0905 / 1 set / IMOC
19. blk_mr2 / 1 set / MR2OC USA
20. GazRev1Tubby / 1 set / MR2OC UK
21. Blaksteel / 1 set / MR2OC USA
22. Dracon / 1 set / MR2OC USA
23. 87glastron / 1 set / MR2OC USA
ForMySin
Post by ForMySin »
24. ForMySin / 1 set / IMOC
If you are in full control you aren't driving fast enough- Stirling Moss
scotty1982
Post by scotty1982 »
10. Scotty1982/1 set/IMOC
GStar
Post by GStar »
To use the Arches positively, the original should be cutted or?
The Groupbuy is for front and back arches or?
GStar wrote:To use the Arches positively, the original should be cutted or?
Yes ideally you will need to cut back your arches to allow for maximum extension from the new arches and the group buy is for the whole set front and back :thumleft:
AlexSW20
Post by AlexSW20 »
One point i wasn't sure about, the original Abflug designed used a front valance which blended into the front arches on the lower edge of the bumper/apron. How will the front arches blend in without this? :-k
splashnatz
Post by splashnatz »
Got any pics of what yours are going to look like yet Ben ?
Alex, we are adding extra parts onto the arch so that instead of it stopping it comes all the way to the bumper and skirt to fit smoothly. If you see the photo below it makes more sense :)
splashnatz - photo below :)
As you can see the arch fits really well, where it stops (near clamps) we have decided to extend all the way to bumper and sill so the finish is more smooth with the lines of the car. More photos to follow
bri0905
Post by bri0905 »
Where can i get a set of those awesome wheels....... :^o
96 Rev 3 Turbo, Done!
splashnatz
CarBen Fibre Creations wrote:As you can see the arch fits really well, where it stops (near clamps) we have decided to extend all the way to bumper and sill so the finish is more smooth with the lines of the car. More photos to follow
that'll help for those without any rear spats. you making similar changes to the fronts ?
Yes this is how they'll be all round, the idea is the people who do have spats and skirts they can cut the arch to suit making them more universal.
stevegts
Post by stevegts »
does the inside lip follow the wheel on top (more rounded)when a proper width wheel is fitted or is the original flare not very contoured to the wheel?
stevegts wrote:does the inside lip follow the wheel on top (more rounded)when a proper width wheel is fitted or is the original flare not very contoured to the wheel?
It follows, what I'll do is once we have them completed I will upload loads of photos so you can see in detail how they look :)
AlexSW20
Post by AlexSW20 »
CarBen Fibre Creations wrote:Alex, we are adding extra parts onto the arch so that instead of it stopping it comes all the way to the bumper and skirt to fit smoothly. If you see the photo below it makes more sense :)
Nice one guys! :thumleft:
24. Nod / 1 set / TwoBrutal
Second build progress photo taken from the other side and from different angle.
Please note that these are only build shots to give you an idea on the arches the final product will look alot different when its moulded properly :)
25. Navz/ 1 set / MR2OC UK
26. Chris69 / 1 set / MR2OC UK
27. jdes / 1 set / MR2OC USA
scotty1982
How are these coming along??
I also thought i would be cheeky and ask if any extra discount would be added as there are over 10 more people then the amount needed for 20%! :clown:
Arches are off the car ready for moulding we should have the finished product very soon :)
Cant hurt to ask but Im afraid no 20% is the best we can do on the arches sorry.
scotty1982
Sounds good, can't wait to see them!
It was worth a try! O:)
Return to “Group Buys - MR2 related”
