Everythings relative to age and milage if you're focusing on reliability
also depends on quality too
In my years of car ownership
( 20
), I've had a few.
and the most reliable cars have been Hondas FACT.
French cars have been 5hoite in my opinion.
and I had a new megane coupe a few years back.
broke down 3 times
Fortunately, the company picked up the repair bills.
I have a 12 year old Accord V6 with 120k miles on it, its only needed discs and 2 rear silencers.
not even a weap of oil leaking, water leaking or anything.
the cars worthless but brilliant
Even other hondas I've owned have been excellent.
Whilst I've seen nightmare bills from M3's
- single Vanos systems
(£2500) replacement which is Beemers variable valve timing.
I've also been shocked at the older M5's with a twin Vanos system
£4K to rectify
3 Series tends to suffer from worn bushes, broken springs.
but other than that, quite a reliable platform.
I've had my M5 nearly a year now
( bought with 22k on the clock
Its been excellent and all its needed is a service which was
£400.
Modern day BMW's have conditional based servicing, so theres the idrive that monitors what needs changing or doesn't.
keeps servicing bills down
That
£400 included oil and filters change.
if you take into consideration to 18k miles oil service change intervals, your overall servicing costs are actually reasonable.
Dont get me wrong, I got quote
£400 to change out the front pads
I still maintain though, the more stuff you put into a car, the more there is to go wrong.
Agreed
- theres usually a reason behind it also.
My X5 was 6 years old when i got rid of it.
The electrics on it became a bit of a pain.
The error thing constantly lit up saying I needed a bulb in one of the rear lights.
Light cluster seemed to accumulate damp and corrodes
Rear Parking sensor failure
- Well.
.can't talk my way out of that one
- Probably too much jet washing
Rear parking sensor loom failed
- Premature corrosion due to water ingress.
the mounting position of the loom retained water.
Electric boot was opening all the time whilst driving too
( faulty switch
- part of the whole number plate light assembly too
£ 150
+ paint
Usually water related
Air suspension failure.
Its goes on tooo.
other than the problems, great car though
62k when i got rid of it
if you're considering an e46 m3 i'd seriously suggest looking at a newer E90 non m spec 330 or 335
Agreed.
similar prices.
335i coupe
335D if you do alot of driving
Boosted up 335i is quicker, faster and more refined than the old M3.
