![Whistle :whistle:](./images/smilies/eusa_whistle.gif)
vashy wrote:Hey Jeremy, I have a couple more questions for you; I might as well ask them on here(:
Would it be ok to tweak fuelling by modifying the intake air sensor signal?
(I know you said it's not ok to modify the coolant temp signal as this affects ignition timing also).
vashy wrote:I was thinking if it could work for 20v throttles!(after doing some reading it looks like ITBs really mess up the MAP sensor readings, and a pot wouldn't be enough, I would need some form of addon fuelling computer or standalone.
vashy wrote:the corolla boys just use a spare 4AGE fuel rail
anyway, you buggers, you're giving me ideas![]()
If you happen to spot any 20v ITBs come up, don't let me know![]()
Bender Unit wrote:FYI John there is a set of ITB's on driftworks for reasonable money.
vashy wrote:Bender Unit wrote:FYI John there is a set of ITB's on driftworks for reasonable money.Smokin' cakes, they've gone already.
For that kind of money though, I think it might be worth getting a set, have a play and see if I can sort the fuelling.
.aw11rally, YHPM!
vashy wrote:
.aw11rally, YHPM!
Bender Unit wrote:Its all in the mapping- a AE101 AE111 Corolla running a stock 20v on open stacks performs very nicley.
When ever you start to look at performance tuning on a 4age you have to accept that your going to have to make a scrifice in terms of drivability or low down grunt; however all of that means nothing if it performs well at the top end in its power band.
The sound from ITB's is worth the few HP you may loose lower down in the power band.
