![Laughing :lol:](./images/smilies/icon_lol.gif)
Rogue wrote:I'm hoping to have draft regulations available by the end of the week.
karldavies wrote:Any update on the regs?
Performance Index
The MR2 Super GT series uses"Black Box" technology to capture information about a vehicle's performance during a race.
The Race Technology DL1 Datalogger uses a built in 5Hz GPS receiver and digital 3 axis accelerometer to provide very precise information about the forces acting on a car at all times, from which can be extrapolated a figure that represents a vehicle's overall performance relative to other vehicles using the same method.
At it's most basic level, think of it as a device that gives your car a score for it's abilities every time you drive it.
Because the Datalogger is totally independent from the vehicle we are able to give competitors much more freedom in tuning and modifying their engines.Essentially, we're not concerned with how you achieve the engine's power output
- just that you don't exceed the limit for the class you're racing in.
How it works:
There are four factors that we need to take into account when calculating the performance index:
- Weight
- Coefficient of drag multiplied by frontal area
(CdA)
- Rolling Resistance
- Environmental parameters
- ambient pressure, temperature and humidity
Of these, rolling resistance can be largely discounted.Since all cars in the MR2 Super GT series are using the same type of tyres the difference between the actual sizes would be negligible.
Environmental factors are measured trackside during the race and used to calibrate the data.
We're therefore left with weight and CdA to consider.
For the purposes of our performance index, we use a standard bodied MR2 with a weight of 1000kgs as our datum.
Given all of the above information, it is possible for the Race Technology Analysis software to use data from the DL1 Datalogger to accurately calculate the power used at any given moment.A standard bodied MR2 with a 150kw engine and weighing 1000kgs would report a performance index figure of 150
- essentially the car's power to weight ratio.
Varying the weight of the vehicle affects the performance index
- a lighter vehicle gives a higher score, while a heavier vehicle lowers the score.
If the vehicle in the above example weighed 800kgs it's performance index would increase to 187.5, or decrease to 125 if it weighed 1200kgs.
The final consideration is the car's aerodynamic efficiency.Using the standard MR2 body as our starting point, reducing the cars coefficient of drag or frontal area
- effectively making it more slippery
- will give a higher score and vice versa.
It's worth noting that some aerodynamic aids can improve downforce at the expense of increasing drag
- which would lower a car's performance index score.
It is therefore expected that most competitors will take advantage of this and fit large wings to their cars.
To summarise, the following things will increase a vehicle's performance index score:
- Increasing the power of the engine
- Reducing the co-efficient of drag
- Reducing the frontal area
- Reducing the vehicle's weight
The following will decrease a vehicle's performance index score:
- Reducing the power of the engine
- Increasing the co-efficient of drag
- Increasing the frontal area
- Increasing the vehicle's weight
The only way to be sure of a car's performance index score is to test the vehicle at circuit, and competitors should be prepared to do this throughout the season.
kaiowas wrote:You might need a minor exception for the"No modifications to suspension pickups" for certain mk1s.
Pre Aug 86 the front top mounts only had 3 mounting points, later cars have 4.
With the control coilovers being advertised as suitable for 86-89 cars I'm assuming they have 4 bolt top mounts and therefore will not fit an earlier car unless a 4th mounting point is drilled.
kaiowas wrote:Also I see that you explicitly allow engines and gearboxes from Lexus cars but do not make reference to other potential sources of production Toyota engines(such as Lotuses) does this mean that they are disallowed or had you just not considered it?
jonb- wrote:Rogue wrote:
I recognise that car, didn't used to look like that though![]()
