Jim-SR wrote:Tom G wrote:Therefore if front and rear piston size is the same, bias is 50/50.
If front area is twice that of rear, bias is 66/33.
making the assumption that the master cylinder is doing the same amount of work for both ends of the car.bearing in mind they are 2 seperate circuits, with a proportioning valve thrown in for good measure!
yeah, sorry that's assuming no proportioning valve
But why shouldn't the master cylinder do the same work for front and rear? I mean, there's only one piston, so same bore for both circuits? Or does the M/C have some kind of proportioning device built in?
