![Image](http://www.celicatech.com/imagearchive/bgbonline/94_205_engine/EG/EG-79.jpg)
toxo wrote:Unless I'm very much mistaken, Allan took his air conditioning out.
Benmoore999 wrote:I put the hanger on to support the chargecooler more.I suppose you would get less strain on the throttle sock.
I thought it may offer additional support when i went on the track.
allan welsh wrote:toxo wrote:Unless I'm very much mistaken, Allan took his air conditioning out.
indeedy air con was removed as the compresser was dead.I'm sure there was someone that managed to run the air con and the fiat unit on std bumper.
There certainly looks plenty of space in there
BLZ-8027 wrote:Ive just boughta spares car with this system fitted
(And standard bumper
is there much gain to be had with a standard engine, and hardly use the car?
BLZ-8027 wrote:good write up as well mate
toxo wrote:I haven't yet decided what to do about running the pump.I don't like the idea of running it flat out all the time.
If I can find one cheap, I'll throw an ST205 ECU in there and it can just run exactly as it would in the Celica
(something like it comes on when the throttle's open past a certain point, and runs for 30 seconds after the throttle has returned).
If not I'll put the ECU money towards a Link and that can run it.
That route is more costly, but will also get me an engine remap which is probably a good idea.
