20g superback Billet 7+7 blade.
GTX style performance upgade.
extended tip and also slightly taller wheel which will be a straight drop in.
the 7+7 extended tip offers a bit more power
the 11 blade is more readily available and better spool, but i thought more top end on a lower boost level would be more beneficial to me.
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/rev4%20tubby/s-l1600%201.jpg)
uprated rebuild kit.
this includes wider spacers to help thrust load with a bigger surface area on the thruster bearing.
the thrust bearing itself is now a 2 oil port design for additional lubrication
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/rev4%20tubby/s-l1600%203.jpg)
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/rev4%20tubby/BdeBMNgWk-KGrHqQOKigEq4PVQwybBK5HctJFYg--_12.jpg)
turbine wheel, only option i had was a stock turbine wheel.
i believe this issue is down to poor oiling and/or low pressure, high heat.
so new one needed
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/rev4%20tubby/s-l1600.jpg)
i also looked into the oil drainage system.
The previous oil drain system may have been the same, but i wasnt supplied with the old one so dont know.
small drainage can potentially cause oil backup in the housing causing it to leak at the turbine side, causing it to smoke when at high pressure, ie full load or cold starts.
the CHRA was caked in oil in this area, so ive since cleaned this up and looked into a larger drain kit.
ive decided to go big.
this should mean a minimum of 15/16mm all the way through even the connection points.
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/rev4%20tubby/s-l1600%202.jpg)
OEM block fitting vs
12mm vs 16mm ID
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/rev4%20tubby/15107426_10154604868275281_2260061289079734292_n.jpg)
new 1/2npt fitting VS
![Image](http://img.photobucket.com/albums/v326/jimbob_uk20/rev4%20tubby/14054072_10154616876475281_2610928162902090339_n.jpg)
