Because of my decision to use a supercharger engine lid i wanted a more elegant solution to moving the engine lid catch than i have seen before, previous attempts i've seen are a crude bracket just bolted to the old SC bracket as an extension, it just doesn't look right in my opinion and i want everything on this car, even though it's highly modified, to look like it was meant to be.
So a better catch relocation solution was needed, for those that don't know a SC catch is in the middle of the lid, the NA are offset to one side.
Now you could move the catch on the car if it was a 4a-ge, but not with a 2gr in the way.
I started off with a Mk2 catch bracket, it lended itself to the job much better than a Mk1 catch bracket.
First it needed the legs shortening by 10mm, then i was able to drill through the existing support for one of the fixings, the right fixing needed a tube nut making captive within some P38, after that the whole area was built up with P38 to make it look OEM.
The original SC bracket was then cut off and blended over.
It does look factory now although there is an odd gap where the old SC catch used to be, i will use a Toyota engine lid sticker in this area to make it look right again, something like this.
![Image](http://i48.photobucket.com/albums/f245/FOXMR2/2007BCMR2076-1.jpg)
I'll work it out later.
![Image](http://img.photobucket.com/albums/v624/paddy1970/woodsport/Woodsport8/Img_2069_zpse53f16da.jpg)
![Image](http://img.photobucket.com/albums/v624/paddy1970/woodsport/Woodsport8/Img_2070_zpsa0d3e29d.jpg)
![Image](http://img.photobucket.com/albums/v624/paddy1970/woodsport/Woodsport8/Img_2072_zps3c03376d.jpg)
![Image](http://img.photobucket.com/albums/v624/paddy1970/woodsport/Woodsport8/Img_2075_zps407f7263.jpg)
![Image](http://img.photobucket.com/albums/v624/paddy1970/woodsport/Woodsport8/Img_2074_zps7590456e.jpg)
The end result should be a SC lid that looks like it was made for the NA
