Goldy wrote:Hrms.
is it worthwhile getting a brake fluid change?? Mine looks a lot darker than it did when it went in.
I'm getting an oil change done.
but is brake fluid worth gettin done as well?
As for 110 on the clock.
10% over still means I managed to hit 100 before stamping on the anchors!!
Brake fluid
- if in doubt, yes! Brake fluid is dead easy to change yourself
- just takes time, and ideally two people and a hose with a one way valve on the end.
You basically open the bleed nipple on the caliper, and pump the brake pedal gently, topping up the brake fluid reservoir as you go
- you'll see the change in fluid colour as the new stuff comes through.
Don't open the bleed nipples too much
- I've found that a little air can get drawn into the caliper as you let the brake pedal
'lift'.
Ideally, the person at the brake caliper should close the bleed nipple just as teh person pumping the brake pedal is pressing down on the brake pedal.
If you're expecting to do some more trackdays, or drive hard, I'd put in some DOT5.1 fluid on the basis it is best to change it again in 18 months
- otherwise put DOT4 in which should last 2 years
(it absorbs water less rapdily than DOT5.1).
DOT5.1 has a higher boiling temperature than DOT4 when
'dry'
(ie new) but once moisture has got in from the atmosphere, it performs worse than DOT4
- hence the need to change DOT5.1 every 18 months if you're doing trackdays to make sure you're getting the best performance.
Cost
: 1 litre of Halfords DOT5.1 is only 8.99, and the bleed kit is about
£7
- add about 90 minutes of your time and the job's done.
As for brake feel
- If you boiled your brake fluid on Track, the pedal would have gone to the floor with little/no resistance as your trying to stop
- this would probably would have caused a serious brown trouser moment!
With pad fade
(when they're too hot) you get a firm pedal, but very little stopping power.
Just ease up on your braking
(break earlier, more lightly) and let the pads cool off.
You don't want to overheat brand new pads like this though as they can crumble away.
What most people are probably feeling at the moment is the glassy surface that develops on the brake pads after hard use, resulting in the brakes not feeling they're stopping the car very well, and you needing to use more pressure than normal to stop the car.
Give it a week or so of normal driving with standard brake disks and the brake feel and stopping power will improve as this glassy layer wears away.
Cars with grooved disks will recover a little more rapidly as the grooves
'shave' off the glassy layer and brake pad material as they are used normally.
