you can see how much better the seat sits now ( old pic..)
new pic.. ill get a better angle one later
Pistols MR2 stories... MK1 and 2zz MK3
Re: Pistols MR2 stories... Race car and Project car..
woohooo.. tyres will be delivered on 26th.. nice soft sticky compound
No way you can get the door shut with the window up with them in?? That looks miles wide!
If you look they are seated different .1st is how it was last year and it was fine no didn't touch anywhere
2nd is how it is now .much lower and sitting much more in.. Look again
Right enough! I saw the first one and just thought no way.
Amazing that it fitted then, the new fitment looks way better IMO.
I fancy a set of Corbeau seats in the Vette tbh... Not Revenge really so much, but maybe A4 or Evolution X. Where did you get yours??
I got it on here;)
+well been busy doing all the little bits here and there... finishing touches and all that..
Fitted a new stereo in the truck.. OMG!!! the wiring so sorted that out ... it now turns on and off with the ignition not more forgetting to turn it off
and i have re fitted all the dash properly so no longer rattles. Also took the clocks out and ordered some new LED backlights, as none of the Lamps worked in the dark pic when i get that sorted..
The car.. re fitted undertrays, fitted the coolant pressure cap to new locations (cross brace in way of standard location)
Fitted new brakes all round (awaiting new discs as ones that came were rev1s )
fitted Engine lid pin
re fitted battery clamp
fitted 5 point harness... very snug. i don't move anywhere when in the car
cleaned inside the car
Wheels lacquered, the rim had extra coat of red first to give it more of the burnt orange look
Fire extinguisher fitted
Tyres arrive tomorrow, as should the fronts discs, then its fit them and clutch and brake bleed then alignment
ohh soo close now..
ohh soo close now..
Such a weapon! Are you going to remove any more of the leathery plasticy dash bits?
When cage goes in the windows will be polycarb, and everything in the doors out and no door cards as will have door bars and the rest of plastic
Just dash has to stay in place.. Regs etc..
Looking good Pete!
Whens your next sprint?
Test day 13th at blyton then first event at snetterton 29thmarch
please like/share/comment on the zombie sprint face book page
https://www.facebook.com/pages/Pistols- ... 0272127049
little update..
Car was fully aligned yesterday so now everything pointing the right way, and camber bolts set
managed to have alittle drive around while there and seat was sat too far back.. so have now moved that, and where i could move it forward i could also lower it too.
tyres also arrived today ready for fitting to the advans
but i wont run them on fridays track day as do not want to ruin them.. so will be running some r888s before dumping the wheels and tyres
also untill the cage goes in there isn't really anywhere to fit the go-pro.. and i wanted to try a different angle so for now how about this
on a side note.. Oppsoite my mate who does the motorsport wiring is a guy who has been racing many many years much endurance racing etc..
was chatting to him and he pulled out a set of 16's track tyres he no longer wanted, that i could use to ruin on a track day, so for track days will be using the momo arrows with used track tyres to ruin. then leave good wheels and tyres for sprints
i then got a call, since chatting and having a look at the car he has been digging around in his hoard of stuff and found a 20litre fuel cell which will fit under the bonnet, along with most hoses i will need for it... so could be losing a lot more weight yet
lets see what else he can dig out
really looking forward to friday now..
Advans look mint , perfect for an upcoming zombie apocalypses
thanks buddy.. they are not close up... but spray can job, good enough to be covered in brake dust...
i do like the "burnt red effect" on the lip
Just picked up a 20litre ally race fuel tank...
So get rest of bits.. Then that'll be lots of weight saved...
Nice...will be curious to see how much weight that saves you. Is it a custom MR2 frunk shaped one? You going to keep the stock fuel pump?
Looking forwards to hearing how the track day testing goes...do you run on super unleaded?
Yeah always super.. Nope its a rectangle one.. See face book page.. From a
midget.. But firs lovely under front.. I'll get aftermarket pump and swirl pot
Also its not just weight saving but carrying less fuel and less sloshing around as the tank is so much smaller
Yeah- sounds sensible- looking forwards to seeing fuel cell pic's, it's an idea I was toying with as well...not so sensible for a road going turbo'd car though
Enjoy Blyton dude
2001 BMW M5 (Bahnstormer) | 2004 RX8 231 (the Racecat) | 2001 Volvo V70 (Swedish eBay barge)
Previous:
1989 MR2 Mk1b T-bar | 1988 MR2 SC Super Edition
Previous:
