REV 1 GT - @ Back Home
CRAIGROBBO
Re: REV 1 GT - @ Back Home
Post by CRAIGROBBO »
Update 29-09-2014
Message from Peter that he has collected my block from the machine shop.
Actual build time now.... :thumleft:
Cheers Craig
CRAIGROBBO
Hi All,
The best present ever arrived this morning!.....
Thanks to Paul @ Whiffbits for his help and Syvecs / Ryan G for uploading the new base map etc!! Top Service guys....
Cheers Craig
CRAIGROBBO
Update 30-10-14
So the block has now been cleaned, bored 86.5, decked & honed.
Then painted with a heat temp paint.
The flywheel, crank, rods, pistons & alloy crank pulley are due back tomorrow from being balanced :thumleft:
Cheers Craig
CRAIGROBBO
Hi All,
Bottom end has moved on a wee bit further, Pistons in place.
Cheers Craig
CRAIGROBBO
5S Oil Pump all fitted and crank sensor..
Craig
ashley
Post by ashley »
Nice :thumleft:
CRAIGROBBO
Hi All,
That's the short block all completed and sealed up - Next week the head will be checked over and fitted. Once in the bay the oil filter will be relocated to the bulk head to reduce heat from the down pipe & screamer pipe.
Things to get ordered this weekend:
Syvecs command switch
Syvecs clutch switch
Might also buy the Syvecs fuel flex unit :thumleft:
Cheers Craig
Shmed
Post by Shmed »
I know they're a bit pricey, but have you looked at the Syvecs Toucan?
January 2014
..the only thing I can promise for sure is slow progress.
May 2015
just have this niggling thought that if I rip out the wiring, then the car will never get out of the garage again.
Still in the garage...
CRAIGROBBO
Shmed wrote:I know they're a bit pricey, but have you looked at the Syvecs Toucan?
Damn you Paul! Why did you have to show me this! :thumleft:
I can see this being on my crimbo list!
Cheers Craig
ashley
Post by ashley »
Planning on running E85 eh? Very nice...what size injectors are you going to use?
CRAIGROBBO
ashley wrote:Planning on running E85 eh? Very nice...what size injectors are you going to use?
Ashley,
At the minute I have a set of SARD 850cc injectors but not sure if I might go 1000cc yet??
Cheers Craig
Shmed
Post by Shmed »
Cheers Craig
Sorry :wink:
I was going to get one, but decided to take an alternative route, mainly due to features per £.
January 2014
May 2015
ashley
Post by ashley »
If you're planning on running high power on E85 you may want to rethink that, from the little I know E85 requires significantly higher fuel volumes to be injected...some research required :study:
Engine is looking good. I've having my block painted in the same colour/paint. :thumleft:
CRAIGROBBO
Hi all,
Little update - Head gasket arrived so head could be put in place which has been re-shimmed while waiting on the gasket arriving... getting closer by the day :thumleft:
Syvecs clutch & cal switch also arrived.
Cheers Craig
CRAIGROBBO
Update 19-12-14
Manifold, Turbo, Downpipe, Wastegate & Screamer Pipe all dry fitted until gasket kit arrives.
Cheers Craig
slipping clutch
Post by slipping clutch »
Very tasty :thumleft:
CRAIGROBBO
Peter on with the timing..
Cheers Craig
CRAIGROBBO
Hi All,
Cant believe its been over 15 Weeks since my last update..... :shock:
Time is just flying by and the car has been off the road now for 16 Months.
Last spoke with Peter on March 26th and the aim was to her back up and running end of April so fingers crossed we shouldn't have much longer to go.
Got a few events planned for May and a popular car mag wants to do a feature so really eager to get her back to have the body work all tidied up rear diffuser to custom fit along with Daie MS front lip... :thumleft:
Cheers Craig....
CRAIGROBBO
Hi All,
So hoping to hear this week about the car, Hopefully nearing completion as the summer is approaching fast and lots planned with the car!
Will update once iv heard some news.... :thumleft:
Cheers Craig
