Track car with a low budget | Powered by Adaptronic
GreddyMR2
Re: Track car with a low budget | Powered by Adaptronic
Post by GreddyMR2 »
Magic Beans wrote:What if it's 3mm? :mrgreen:
I would really notice 3mm difference on door spaces with my eyes :) Now I can't see any difference.
GreddyMR2
Post by GreddyMR2 »
Help me decide on a color!
I can't decide wheather to stay with pink/black or make it all black? :roll:
As mentioned before, interior will be black with white cage.
I think maybe black with white wheels should look nice.
slipping clutch
Post by slipping clutch »
GreddyMR2 wrote:Help me decide on a color!
All pink would be nice :mrgreen: :mrgreen: :mrgreen:
matt-mr2
Post by matt-mr2 »
How about something like this
Or
Magic Beans
Post by Magic Beans »
Something which can easily be matched if you have to replace body parts :thumleft:
GreddyMR2
Post by GreddyMR2 »
All pink? Ehh, maybe not :D
I'm not sure if I want to mix a lot of colors. But maybe some nice vinyl would look good.
I think black one would be the easiest way if I need to find a replacement parts. And it can really happen as I plan to go some racing from the strip line :)
This would look the best for me, but really too much work to change the whole color.
By the way, maybe someone knows somebody who's braking a hard top mr2? I am looking for a roof to weld it instead of t-tops.
:shock:
So, not only have you cut and shut 2 MR2s together, you're now wanting to cut and shut a roof on :pale:
Each to their own, but the car just spells 'death trap' to me.
GreddyMR2
Post by GreddyMR2 »
RedMR² wrote::shock:
Well, there is no other better option, I guess. Do you mean it will rust soon or is weak?
It will already be weakened by being 2 cars welded together, and then further weakened by more cut and shutting on the roof.
I couldn't recommend enough trying to get hold of a complete original chassis, if you can, that is.
GreddyMR2
Post by GreddyMR2 »
I'm not sure if you saw that a full rollcage is fitted. It makes the car much stronger than any standard car :) The cage is not bolt on, it's welded to the chassis everywhere. I think I can cut as much as I need now to save weight and the car will still be strong enough.
I'd just hate to see the car tear itself apart with you in it. It may well be all welded up, but I've seen the aftermath of cut and shuts, which is why I wouldn't condone one.
GreddyMR2
Post by GreddyMR2 »
I fully agree with you that is's not as good as would be if the car would not be welded from two, buy really, we had no options. And this is why we fitted a cage.
We'll see in a future how it goes, but I'm sure it won't split.
By the way, regarding the roof. I think I will not cut the center part. We would just weld a roof on a top, so I can't imagine how it can be weakened more by doing this. I imagine opposite, it will be stronger.
GreddyMR2
Post by GreddyMR2 »
I know you'll say I'm insane, dumb and so on, but I'll take the risk :)
Today we fitted a hard top.
Next week car is going to be painted. I guess it will all be super red.
Magic Beans
There's some serious work gone into it, I hope you get the results you want :)
GreddyMR2
Post by GreddyMR2 »
Thanks Phil! :) I'm sure I will get what I want, but I'm afraid I won't finish everything untill May. Time attack is on 17th of May, but I still need to run the engine in and tune everything. But I hope painter will do the job during March and I will assemble everything during April.
Today done some more work.
Fitted the dash, dissasambled front, removed anti-vibro material from interior and some other small things.
Here is how somebody repaired car previously... Terrible
DAN_REV1_TURBO
Post by DAN_REV1_TURBO »
Wow, never seen anybody chop a hard top and ditch the T-Bar before!
GreddyMR2
Post by GreddyMR2 »
I believe it's not usual in UK as you have as many shells as you want. And they are quite cheap. Unfortunately the situation with LHD is a bit different...
slipping clutch
Once again big credit for your hard work and dedication on this project- can't wait to see it finished.
GreddyMR2
Post by GreddyMR2 »
My dedication is going down when I see how much work still left...
Anyway, I impatiently want to drive, so I will have to finish somehow.
Also, finally I decided which color it will be. Was thinking between super red and crimson red and I chose crimson :) It will be fully red, no more black tops. I guess it should look cleaner this way.
GreddyMR2
Post by GreddyMR2 »
Some small things done and bought while the car is being prepared for painting :)
Hopefully is should be finished to prepare everything for painting this week and I hope to have it painted during next week.
After that will be puzzle game :D
Flocked dash
Aeroware lip and side ducts from carbenfibre
And a seat that hopefully will not be too big
