Was your Mk2 Master Cylinder a Rev 2?
See link: http://www.imoc.co.uk/forums/viewtopic. ... r+cylinder
If so what year and what model specifically?
I know i would need a mk1b Servo by the way
seankenyon wrote:Peter,
I know i would need a mk1b Servo by the way![]()
Lauren wrote:
Pics of turbo manifold, Peter? Where was it from?
PW@Woodsport wrote:At the bare minimum you will require a USDM Mk1 engine harness/ECU and AFM plus dizzy and injectors, everything from a USDM car, and that is just for low boost mode.You'll also need an HKS gasket, studs, and a small fortune in other bits.
Oh and you'll also have to know what you're doing.
PW@Woodsport wrote:If you think about it how is a Uk Na MAP sensor going to see boost when all it ever sees is vacuum? What mapping is there inside a UK na ECU for boost even if the MAP could register positive pressure?
Using the USDM AFM means the air going into the turbo is metered and fuel allowed for regardless of boost up to 5 or 6 psi then it will all max out anyway.
You could maybe bluff the job with RR fuel pressure reg but that's not very precise.
Lauren wrote:Okay, I get that, as you are talking about Peter turboing a 4AGE.
If you did have all the GZE stuff, though it's considerably easier and easier still if it's a later spec DLI GZE with MAP.![]()
Crap thing with an AFM is that you can't run an external wastegate as unmetered air doesn't go down too well, so some kind of recirc' setup is needed.![]()
If an HKS VPC can be aquired you can then ditch the AFM, solving that problem.
Just wondering if an HKS VPC could be a way of avoiding the hassle to get all the US stuff? Maybe added with an SAFC, could be an easier way of doing it?
I think Peter/Sean should start another thread!
