there are lots of places that can do 4 wheel alignment, but not very many that can do it properly.
99% of places user laser setups now, which in theory should be quite accurate, but they mount onto the wheel in a retarded manner and you can get a degree or so of inaccuracy just from the mounting of the equipment onto the rim.
all of the laser printouts ive ever seen have been fairly inaccurate
the other problem is that places using laser equipment are doing so because its easier.
this means its faster, which means a cheaper price to the customer, but it also means that they arent going to spend as long setting things accurately.
they just get one thing close, then adjust another, which consequently pulls the first thing out of alignment
(camber and toes generally affect one another, and it takes 2 or 3 tweaks to get both correct)
people that are looking for precision use good old strings, and camber gauges.
you create a parallel rectangle of string around the car equaly spaced side to side, then measure the differences in distance from the front of each rim to the rear of each rim, this gives toes.
and the camber gauge just sits up against the top and bottom of the rim and reads off a digital angle relative to perfectly flat.
you obviously need a flat floor for this so that the car is perfectly level to start with.
weve got one concreted into the workshop floor
it obviously takes a fair bit longer to do it with string, but its the only way you can be sure of the accuracy.
its still the method of choice in top end motorsport, even F1 last i heard
(although their methods for mounting the string are rather more exquisite lol).
thus the best place to get this done is at a motorsport preparation company! costs are usually
£250+, but you get what you pay for
if you take your car on track id definitely have it done this way, and have it done at least once a year
(ideally you want to do it after every event, because you can come back and say
"my car is doing this.
" and if youre using a decent motorsport preparation company, they will know what to adjust to improve the car!!).
if you just drive on the road then it depends on what you want to spend really.
some places will do 4 wheel laser alignment for
£150, make sure you get reports from other people on what their work is like though
the place i work is half way between Alton and Petersfield in Hampshire.
i cant remember what we charge off the top of my head, but its somewhere between
£250-300.
its a pointless exercise taking a car for alignment though unless youve made sure that all the toe adjusters are freed up.
the rear tie bars are ALWAYS seized, im yet to see a car that has original ones which arent after 17+ years of english weather.
even the front ones seize if they havent been touched in a while.
it took me 2 hours yesterday to free mine off, and they were last adjusted 2 years ago!! i still havent fully freed one of them
(just enough to adjust it where i want it), im going to have to remove the ball joint from the hub to do so because i need to get a die on the thread to clean it out
