Anyhoo, I'd have one coming out of each vent or just underneith them.
cantfindausername wrote:Screamers shouldn't have too much pipe on them or it could restrict flow.Not that I imagine you'll be needing to divert much gas round that monster.
Anyhoo, I'd have one coming out of each vent or just underneith them.Have flames licking down both side of the car
cantfindausername wrote:Yeah I have, and I wiggled it a couple months ago and remember it seemed..
a little playful to be honest.
But then figured that all turbos feel like this when they're dry.
It will be perfect when its got 40+psi of oil to float on
cantfindausername wrote:no worries.And good luck getting that beast on there! I take it you're going for 550+whp if you're running 1150ccc injectors?
greeny wrote:
And one more thing does any of the turbo gurus know how this compares to the T88? Sergey on the mr2oc.com has brilliant spool for the power(700+rwhp) and size of turbo.
Cheers Michael.
cantfindausername wrote:How long till you get this monster sucking in small children and animals?
Steve Horrocks wrote:xxxx me fella!![]()
that's chuffin hoooooooooooooooge!
bet that kickes you in the back like an angry stallion!
cantfindausername wrote:best bet is to jump on the US board.They're more familiar with these large turbos.
cantfindausername wrote:How is a dual WG going to help lag? Surely lag is the result of the cars inability to produce the required gasses to turn the turbine fast enough?
The only thing a dual WG will do is give smoother control, and the ability to run a low boost application.![]()
- and look the mutts nuts.
