Mikejc wrote:
ENSMR2 wrote:
It's not different if it's been done though.
Boot/rear bumper exit would be different or even engine lid exit.......
Engine lid exit has been done
Mikejc
Yeah?
Anyone got any pics?
Like the man said, got any pics?
Mikejc
Yeah?
Gordy wrote:Idea for you: Split the exit from the turbo: route the main feed down to a normally positioned exhaust, and feed the wastegate output (straight-through and unsilenced) through the side exit. You'll get 'normal' sound while pootling around and a roar when the wastegate opens. Woo hoo
skinthespin wrote:why do the seals wear out with no back pressure?
70by wrote:seals wearing out! back pressure needed for turbos! what have you lot been smoking get the gas out quick as possible,a free turbo is a happy turbo
jonb- wrote:Holdddd on.
Now i'm not the most learned chap when it comes to engines but i'm pretty sure, on NA's at least, you need some """backpressure""" not because backpressure is good, but if you go too large on your tube you lessen / lose the scavenging effect because the gasses are moving slower in the large tube (nothing to do with backpressure hence the """). Backpressure will exist in any system unless it's just a straight pipe.
Now, i'd assume this is most important off the cylinder on an NA car, so in the manifold. The only problem with our turbo cars is the f**koff turbo creating huge backpressure and runing the airflow, so there goes the main benifit of having a tuned exhaust size and length.
Post turbo it's just about getting the gasses out as quickly as possible, if the turbo is having to exhaust into a +ve pressure it's only going to slow it. Which is bad.
What and why this does to the seals i don't know, though i tend to believe what Jonno says. Perhaps you care to explain Neil?
jonb- wrote:but if you go too large on your tube you lessen / lose the scavenging effect because the gasses are moving slower in the large tube
skinthespin wrote:
I still cant get my head round why the seal life would suffer though?
