Mikejc
xxxx wrote:no i'm not saying don't buy them i'm just saying that they aren't ment to do the job there rx-7 injectors made to fit.where you can get made to measure products for the 3sgte from a variety of places.
And paul i see this is yet another attempt to take a cheap shot at me..
nice one.
one day you'll stop complaining and putting down other companys and look at your so called"p&l performance" and see how many complaints you recieved from the mr2oc about you dealings.
If a company has brought out a good product then i respect that, i don't put people down just for the sake of it unlike others.I have good relations with rogue and fensport.
Tim
xxxx
xxxx wrote:and see how many complaints you recieved from the mr2oc about you dealings.
Tim
xxxx
xxxx wrote:why does your"www" go to p&l performance then.
Tim
xxxx
KiwiMR2 wrote:I get the impression the OEM fuel pump is getting a bit of a rough ride here, AFAIA the stock fuel pump is good for over 395rwhp![]()
This makes an interesting read:
http://www.mr2oc.com/showthread.php?s=&threadid=31686
There are a few"debatable
" assumptions used but what can ya do.
KiwiMR2
nutter wrote:If you look at the americans.One of their first mods to the fueling system is a decent fuel pump
(normally walbro).
At the moment they're a bit ahead of us with mr2 tuning
(we're catching up though
(normally walbro).
No sh!t about making assumptions!
xxxx wrote:Andy i was doing these for£399 set of 4 delivered.
Drop in 800cc sard injectors.
If anyone is interested drop me aline at [email protected]
I will also do price matching if any company in the uk can beat that price all in to your door.You will also get the added bonus of buying from an established uk mr2 specalist which means full after sales service if anything happens or you need help.
Tim
xxxx
MR2Mania wrote:KiwiMR2 wrote:I get the impression the OEM fuel pump is getting a bit of a rough ride here, AFAIA the stock fuel pump is good for over 395rwhp![]()
KiwiMR2
No sh!t about making assumptions! For a start there's this:
"Also, headlosses caused by the fuel filter, fuel lines and the injectors themselves have not been factored in, so you can expect real fuel delivery to the intake ports to be a bit less than this"
But the real fault in their theory is that they've shown that the fuel pump can supposedly flow for that kinda power at ONLY 35PSI FUEL PRESSURE!!! That's what the fuel pressure should be set at STATICALLY, ie OFF BOOST.As boost increases, the fuel pressure goes up accordingly
(see my earlier post, about how fuel flow for ANY pump drops as the pressure increases).
So, unless you can get 400bhp from a normally aspirated 2 litre, that article proves NOTHING!![]()
I've come to my conclusions about the fuel pump based on the many MR2s that I've seen tuned on a dyno at a well known tuning place.If we compare Rev1/2 MR2 turbos to ST185 Celicas, which essentially have the same injectors, engine, turbo, etc.
One of the only differences is the fuel pump! The ST185s seems to be able to get about 280FWHP without needing to do anything more to the fuel system, yet ALL Rev1/2 MR2s that I've seen on that same dyno could not go more than 260FWHP.
And I've always suspected the pump as being the problem.
And the Rev3 shares the same pump, just has bigger injectors.
However, I've never done a direct replacement and back to back comparison to prove this.
If I did, then maybe people would believe me.
BenF wrote:Dino, I've got some video footage of mine on a RR at T&M in Colchester showing fuel rail and boost pressure gauges side by side as the car did a power run.
There may be some differences between dynos, but mine was putting down~250 RWHP and just over 300FWHP, with boost creeping to 18-19psi.
I'll see if I can dig out the footage of the gauges to see if we can answer this question.
