The problem is the mini doesn't use a
Also, you're going to need some aftermarket engine management.
In terms of re-circluating dump valve/Compressor Bypass Valve,
Prob in terms of intercooler the MR2 turbo one MUST be the easiest, because you know it will fit and will more than be up to the sort of boost you'll be running.
Good luck, I'm going to be following your progress with interest
Jim
