[Mk2] [Turbo] Side Mount Intercooler inlet temps back to back
Re: [Mk2] [Turbo] Side Mount Intercooler inlet temps back to back
IMO no shroud is the way to go...
I should say I am not going to be going for big power with my 2, just wanting to make if efficient (plus I'm a bit of a geek so find these things very interesting!)
Don't think there is any doubt that the uprated coolers are better than the standard, I am just interested to see how much better.
I've found some flow numbers, not sure how reliable they are.
They are from a PP cooler for sale ad on MR2.com
Stock Intercooler: 172 CFM
ST 185 RC air to water Intercooler: 230 CFM
Greddy: 253 CFM
Spearco: 320 CFM
Garage Fukui/A'PEXi/Phoenix Power IC: 387 CFM
http://www.mr2.com/forums/threads/83329 ... kit-(RARE)
Looking at pictures of the Greddy and it's copies the first thing I noticed is that the pressure tubes have a curved external edges on the Greddy. This will obviously make a difference to the air flowing through it helping to direct the air through the fins rather than it hitting a flat wall as with other coolers. I have also found some pictures on the Greddy site of their other coolers showing fins inside the pressure tubes, not sure what the cheaper coolers have. More surface area = more heat transfer, but just sticking fins in isn't as efficient for flow, they need to be well designed (which I imagine the Greddy ones are).
Greddy site pics:
Greddy: 253 CFM
Spearco: 320 CFM
Greddy site pics:
Some interesting numbers there
phoenix p intercooler
phoenix powers the best sidemount
Ok worms are all over the shop on this thread ... if you run a side mount run 50/50 water/meth , a boost in performance , no heat soak drop in performance .. win win
Just make sure you're compression ratio is over 10:1, otherwise it'll drive like a diesel
ashley wrote:Just make sure you're compression ratio is over 10:1, otherwise it'll drive like a diesel
Hahaha ha ... worms ..... worms everywhere
Which is better: turbo or v6?
Benfacer you should buy the Greddy SMIC - that's my Ebay ad
It's banter...a reference to some of the great, unresolved IMOC debates...
- Does water injection work/ how does it work
- Should you lower your compression ratio to run more boost
- Is a v6 better than a modified turbo
All have produced large cans of worms when discussed on here over the years
Ha ha .. yeah bit of a private joke , sorry ... as ash said opens big big cans of worms on this site .
Me i ran an ebay xs power cooler and hardpipe kit plus 0.7mm jet single stage water/meth kit ... lowest temp on my air charge tem gauge 18c ... made a vid and worms hit the fan lol ..
I know it picks up hp ... why well get ready for more worms ... 17 pages and we were still discussing why ? ... bottom line IT WORKS
Lol I get that ash, but I think the post is about max air flow - surely that's not a unsolvable mystery? The PP core is about 30% bigger than greddy iirc so should have a higher flow rate and maximum cooling power I'd assume?
I did have a feeling this would open a can of worms! That's why I was trying to concentrate on finding numbers or tangible differences (like fins in pressure tubes)
I would love to CalMac but just bought a exhaust so going to have to stop spending for a couple of months!
CalMac wrote:Benfacer you should buy the Greddy SMIC - that's my Ebay ad
